TURBOSMART : NOW AVAILABLE HERE AT LETHAL PERFORMANCE
LethalPerformance
South Florida
www.lethalperformance.com
Hey All!
Happy to introduce the Turbosmart Line-up for 2021 Bronco and Bronco Sport!
With 2 Innovative units, each with their own purpose, Turbosmart has kept up with their excellence in turbo technologies and given users a great way to make some more sound with the opportunity for big potential!
Turbosmart BOV Kompact Dual Port VR13
Highlights:
- Give your truck a mean BOV sound
- Stronger than the factory eBOV
- Billet aluminum construction
- Uses dual port venting system
- Improves response & thermal performance
BOV that Fits with Aftermarket Intercoolers
Your EcoBoost deserves a big, mean, and aggressive sound when all that boos pressure needs to be released, and the Turbosmart BOV Kompact Dual Port VR13 gives that to you. The BOV Kompact gives you a true BOV operation and sound, and this variant from our friends over at Turbosmart even fits onto aftermarket intercoolers. Just like its predecessor, the Turbosmart BOV Kompact drops right into place of the factory eBOV and comes with everything you need to get it up and running on your truck, all without throwing a CEL. The BOV is less prone to leakage, has rapid response and better thermal performance while handling much higher boost pressures than the stock eBOV, making it perfect for high-powered builds. Hybrid or large flowing turbos with OE electronic diverter valves will benefit from the lack of leakage; the turbo charger and wastegate will not be stressed by the EM achieving its target boost. The dual port design also vents to the atmosphere and then back into the air intake.
Billet Aluminum Construction with Drop-in Design
Each BOV and fitting is made out of CNC machined billet aluminum, which gives it greater strength and durability over the factory plastic eBOV. Just unplug and unbolt your OEM Blow-Off Valve, and install this product in its place. You can do this without adapters, hoses or extra assembly. You will retain OE control of the BOV's operation.
(Fitment: 2021 Bronco 2.3/2.7L Bronco Sport 2.0L)
Check it out here below!
https://www.lethalperformance.com/turbosmart-bov-kompact-dual-port-vr13-2021-bronco-0223-1082.html
And for those who need are looking for an OEM look and sound with performance…
TurboSmart Blow Off Valve Kompact Shortie EM Series Plumb Back VR13
The award-winning Kompact EM series Blow-Off Valves, are the world’s first truly plug and play Blow-Off Valves. Simply unplug and unbolt your OEM Blow-Off Valve, and install ours in its place.
Still plays the role of the OEM diverter valve with a better look, sound, and capability.
Check it out below:
TurboSmart Blow Off Valve Kompact Shortie EM Series Plumb Back VR13 (2021 Bronco) - 0223-1282
Have questions or want to get something on order? Feel free to reach out to me or any one of us on here, shoot us a call at 561-753-8105, or shoot us an email at support@lethalperformance .
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
A51Asheville
Dane
Asheville, NC
2022 Black Diamond Sas Mid Package
Are there any performance benefits to BOV's? (pardon my ignorance to the topic) Or is it just to achieve the desired sound of a turbo?
LethalPerformance
LethalPerformance
South Florida
Ultimately, it is for those looking for better sound as well as higher endurance. Although, if it is venting to the atmosphere, like Dual Port, it is not recirculating as much hot air as it was and in many scenarios, lowering charge pipe temps slightly and better throttle response.
Ford Bronco TURBOSMART : NOW AVAILABLE HERE AT LETHAL PERFORMANCE 1638389275731-png
A51Asheville
Dane
Asheville, NC
I truly appreciate the simple and transparent response. Cheers!
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
I was literally, just now, going to do a search for "BOV". I would like to have some BOV sound but nothing too aggressive. Do you have a sound clip?
ROKBRNC
NorCal
2004 LJ on tons, 1970 Bronco, 2019 Tacoma TRD, 2022 Audi SQ5
To each their own, the whoosh/chirp sounds are annoying enough on the imports, not something I would need on an off-road rig…not to mention my rear end makes plenty of sounds on its own :cool:
LethalPerformance
LethalPerformance
South Florida
We have both valves on the way
Should have some sound clips here shortly, but definitely should produce exactly what you're looking for. Will update the forum as soon as I got it!
Ford Bronco TURBOSMART : NOW AVAILABLE HERE AT LETHAL PERFORMANCE 1638389275731-png-png
Rosalieee
R
LA, CA
Raptor, BMW M3 Competition X-Drive
Is there any benefits to these two over the UPR offering that I already purchased?
