Tube Door Durability
KyTruckPlant
Goshen, Ky
05 Mustang, 05 F150, 08 Expedition EL, 23 Bronco
I've never owned or inspected a tube door. What should this be made of, if the aluminum housing cracks that easily?
Ford Bronco Tube Door Durability 1608994117031
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Hand built one-off set... made before testing and tolerance engineering.
I wouldn’t worry about it.
Raptor911
Raptor911
Broadlands, VA
Ford said it will be made from aluminum. It is a factory part so it will be covered under warranty
North7
North Texas
SUV
Looking at the door from an engineering perspective, the cracked "Cover" may be a non-structural member. Depending on the construction under the cover, the tubes maybe welded together to carry the load. These doors were supposed be to crash tested so most likely the cracked "Cover" is not a safety issues but a cosmetic issue that would be covered under warranty. However, this maybe an early design that gets improved before production.
Ford Bronco Tube Door Durability editor%2F1597333611816-sideviewbronco2doortubedoor
Rydfree
Benny
Alabama
That's a pre-production plastic piece .
People need to chill until they start actual production vehicles coming down the line ,LOL .
Desert_6G
Phoenix, AZ
Ranger
That piece is probably plastic since it's just a cover for the handle. Don't quote me but it looks more of a plastic crack than metal or aluminum. It probably got banged around during transport.
BroncoBLMT
Patrick
Vienna, VA
F250, Silverado, & Tundra
As I recall that was asked at the event and the Ford rep said it was plastic in the prototype but would be metal in the final version.
I recall the same. I expect the production version that hits your driveway will be good to go.
