Trouble removing beauty rings
wetdog
Bruno
pacific coast
2019 jl
If you do f it all up ,take a 1/16 high speed cutter wheel Dremel or air tool and carefully cut a slot in in then get a big blade screwdriver the bigger the better and hopefully it has a hex shaft. Put a wrench on the shift push in hard and turn ccw.
If that doesn't work drill head out and remove ring then try vice grips on exposed bolt a small pipe wrench with good sharp teeth works well too,been there and back good luck
Broncus Amongus
Broncus Amongus
Cody
Mississippi
Ford F-150
Update coming this afternoon. Been out of town over the weekend. I do appreciate the recommendations. Going to start with a breaker bar and rubberband when I get home.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
