Triple fog lights + ditch lights backlighting setup?
BadlandBill
Bill
I recently purchased the @Diode Dynamics Triple Fog Light Kit and a set of Ditch lights from @4x4TruckLEDs.com and have them hooked up to upfitter switches 3 thru 6 (3=yellow fogs, 4= white fogs, 5= combo & 6=ditch lights).
what I want to do is find a way to hook up all of these so that the backlighting comes on with parking lights. so my question is:
1. Is this possible? if so how would I go about hooking it up? Would it be too much amperage for it to handle?
2. if not possible then can I hook the 2 purple BL wires up together and use upfitter #2?
I did also buy the Raptor Grille 3 lights along with the headlight adapter harness from F150Leds and tried running the purple BL wire and tap into the same place the grille lights went but nothing comes on.
Appreciate any assistance.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
You just need an add a fuse tap - Domenico- connect our back light control wire to it and install it on the fuse panel easy
