Transform Your Bronco Into a Mobile Basecamp!
wheelsfeels.com
wheelsfeels.com
Houston, Texas
wheelsfeels.com
Ford Bronco
Storage System for your 6th Gen Ford Bronco 4-doors (2021–present), your trunk and adventures will always be organized. Refined, high-end design crafted with attention to every detail.
No drilling required — installs easily using six bolts.
Built tough: holds up to 200 lbs in the drawer and 400 lbs on top.
Inner drawer dimensions: 26.9" D × 30.1" W × 5.5" H.
Ford Bronco Transform Your Bronco Into a Mobile Basecamp! 2
Covered with premium soft black carpeting (you can also choose beige varnish)!
Enjoy the convenience of a camp kitchen with an integrated table, sink, and faucet — it’s like bringing your home setup on the road.
Ford Bronco Transform Your Bronco Into a Mobile Basecamp! 12
Create a full-length sleeping area with our flat, supportive platforms. No seat removal needed. The total sleeping area measures approximately 75" L * 52" W — spacious enough for two people to sleep comfortably.
Ford Bronco Transform Your Bronco Into a Mobile Basecamp! 14
Use the adjustable dividers included to keep your gear organized and secure. 78 space customization options to fit your setup.
🇺🇸 1-year warranty. American-made. Worldwide shipping.
Ford Bronco Transform Your Bronco Into a Mobile Basecamp! 9
Ford Bronco Transform Your Bronco Into a Mobile Basecamp! 15
Ford Bronco Transform Your Bronco Into a Mobile Basecamp! 18
Ford Bronco Transform Your Bronco Into a Mobile Basecamp! 17
Ford Bronco Transform Your Bronco Into a Mobile Basecamp! 4
Ford Bronco Transform Your Bronco Into a Mobile Basecamp! 13
flashpunk
San Francisco
This is a nice design!
Is that top panel affixed to something or can it just be pulled off? If it's not attached somehow it could potentially go flying in an accident.
wheelsfeels.com
wheelsfeels.com
wheelsfeels.com
Houston, Texas
wheelsfeels.com
Ford Bronco
Hello! Thank you for the good question. Yes, you have 2 options:
1) The top cover is more than a lid — it’s a pull-out deck. Slide it out to access deep cargo — even a fridge or cooler. Want flexibility? Leave it free-sliding.
2) When closed, special locking blocks prevent any vertical movement. Want to make it permanent? Fix it with screws.
