Tow package
Bronco-eer
Adam
Charlotte, nc
19 Tundra, 15 Jeep Jk
Hey. Is this supposed to be a charge on the New bronco, or did I read somewhere that it’s now a standard feature on all broncos?
Thsnks
MNBigfoot
MN
For MY24 they are pre-wiring some of the harness from the front to the rear, and it becomes a plug and play dealer install, instead of a factory install.
PlayTime
Patrick
SoCal
'23 2dr 2.3L OBX non-SAS Eruption Green
My pending 2024 window sticker shows that too, the package is Dealer Installed Option. I'm pretty sure that I remember reading that the harness is from the factory on all builds, like you say.
Happycampinman
Ford Bronco
I’m curious. What are you towing that you feel you need the tow package option? The only reason I’m asking is because I have never looked at my Bronco as a tow vehicle.
Bronco-eer
Bronco-eer
Adam
Charlotte, nc
I guess I worded this wrong. Not towing anything. Should I be paying 500$ for the tow package. When I signed up it was a factory option for 500$. Is it now included in the price and I don’t need to pay 500$?
PlayTime
Patrick
SoCal
I only recently picked up on a custom order that someone dropped that has that dealer option on it, I guess Ford builds only recently changed and there's lots of before-and-after search results. If I can weed through the thicket I'll let you know (y)
AZBronc24
Rich
Breckenridge MI
2014 Ram, 2010 Camaro,
Interesting, I wonder what the issue has been going back and forth between factory installed, then dealer installed, etc and then the cost of it included or not?
HolidayDog
Everglades
MT
24 Everglades
Everglades
I just picked up a stock Everglades today. The wiring is in and ready for plug/tow.
If you have a Bronco with a tow package it’s time to buy a raft and trailer. Problem solved.
MNBigfoot
MN
If you have a $500 tow option on your sticker, your dealer should have installed it, for nothing (since you've paid for it). If it's not on there, you at least have a harness to the rear of the vehicle that wasn't standard until MY24. If you don't plan on towing anything but want a receiver for a rear rack or something, the Curt receiver for around $100 is the way to go, takes 5-10 minutes to install.
GoHack
Palmdale, CA
'25 Bronco, 2.3L 4-Cylinder, 7 Spd. Manual, 4 Door
I just bought a new 2025 Bronco Badlands. DOM 06/20/2025
How, and/or where do you check for the Tow Package Wiring to see if it was installed?
If it was installed, that would be great. 👍
Thanks!
GoHawks63
George
Metro Detroit
2024 Bronco Wildtrak, Cadillac CTS-V Coupe, Roush Stage 3 Mustang convertible
The wiring harness from the front to the rear of the vehicle comes from the factory. The connection is behind the panel in the cargo area on the driver side.
The Dealer Installed option includes the module and the hitch.
The module allows the car to recognize that a trailer is attached. It enables sway control and you can see the feature on the screen. You can also access the trailer light test from the FordPass app.
GoHack
Palmdale, CA
Thanks!
On my 2023 Bronco Black Diamond. you had to wire it from the engine compartment, on back.
On the 2024 + models, they made it a whole lot easier.
