It might be possible but you would have to be perfectly straight in order to not scratch the Bronco pillars. I haven't tried nor have I thought about what it might look like under the lifted top with the tire swing gate closed. If the weather ever turns warm again and I can take the top back off I'll take a look...Ok...so dumb question, but my garage is small and I need to back into it to fit, could I basically back in under the lift top venture pro with the top on it as apposed to pulling in? I'm sure the rear tire factor will put it far back, but would this work? Any chance you could do it in your garage with a pic? Haha...I also have the Badlands sas loaded in area 51.
