To Buy The Towing Capability Package or Not?
reigny
Karen
Delray Beach, FL
Ninja 650, 2003 Honda Shadow Ace
I'm placing my order for my Outer Banks Bronco. I'm getting 2.3 and non SAS which allows a faster build. The Bronco builder at the dealership says if we drop the towing package we could get our Bronco much faster. Can i install the entire package after the fact, including the outlet? Or should I be patient and order the tow package with the dealer now?
Toastedtostito
Steven
Thornton, CO
Nissan Xterra
I believe you can add "the tow package" afterwards. The guys at TFL seemed to be able to add a hitch and wiring to their first edition. Unless there is some secret thing to the package that I don't know about.
Bituman
Bob
Phoenix, AZ
F150 Raptor, Vassago Mooseknuckle, Turner Czar
To be clear, are you saying you think “the tow package” can be added later as a dealer installed item? In other words, it would be the identical as if it came from the factory. Thanks.
Tonka1
Brad
Green Bay, Wisconsin
Jeep Wrangler Willys
The guys at TFL had a terrible time getting the parts to make it happen but eventually obtained them. The big problem sounded like the wiring harness. The plugs were not pre-installed, so they had to make their own. I like the look of the Ford hitch vs some of the aftermarket hitches that I've seen, so I plan to wait. Plus, my vehicle must be able to tow right away.
reigny
reigny
Karen
Delray Beach, FL
I am waiting to hear from the dealer if that's possible. Otherwise I'm curious if i can install one equivalent.
F OR D
BD Green Machine
like a new order or modifying existing? if it is new who know what constraints will look like by the time you are picked.
get what you want/need. if you want it wired (i.e. tow) i would have it done stock, if you just want a hitch for a bike or something do aftermarket.
Rick Astley
Up Doug's ass
d
You need to assess what your towing needs are and what connector you want to run.
Your standard 4-pin will be easy enough to wire in yourself and should plug and play off the canon in the quarter panel. But if you're needing to tow anything reasonable and have trailer brakes (personally I like trailer brakes on anything over 3K pounds as it's a considerable % of the Bronco vehicle weight), then you'll need the 7-pin harness and you have a BIG job on your hands, especially as trailer sway control and the other Ford tech related to towing is only available with the 7-pin, and you'll still need to learn to use FORSCAN to try and find where to unlock trailer sway, if possible.
You haven't indicated your personal capabilities in terms of vehicle modification so i'll withhold any other feedback as I don't know if such a job would be a walk in the park for you, or something you've never done and have no tools/equipment to do anyway.
Big Island Bronco ?♂️
Motown, Motor City, DeTwah, Detroit
XJ Cherokee, 1971 Z28 R/S
My first edition just got scheduled for October 1 and it has a tow package. There is no way for a dealership to know what commodities are going to be the leading constraint at M.A.P. TFL had a hell of a time and they still couldn’t get the seven pin connector for the tow package plus when it’s all said and done they’re probably going to be in it for $1000! Personally I would order exactly what you want because nobody can tell you what may or may not cause a delay.
reigny
reigny
Karen
Delray Beach, FL
Planning on towing a motorcycle only.
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
I bought the hitch and wiring harness. They’re at my home. I’m not in love with either. I think I’d buy a Curt and no-splice kit. The Ford requires a bumper removal and the aftermarket ones don’t.
Liberty
Bill
Central Illinois
Chevy Silverado, Black Diamond Bronco
Phil (@flip) is a dealer rep with several broncos of his own and is on the leading edge of the post sale tow addition. Not easy but doable. Check out his posts
Rick Astley
Up Doug's ass
d
How heavy is the trailer, how heavy is the bike, how much other gear?
Total static tow weight?
Tongue weight?
Unless we're just going ultra-vague here and i'll respond with "might work! Or not". But you're asking a serious question so i'm trying to get more info to give serious feedback.
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
Simply splicing in wiring is not an option on the bronco. Those that opted to have a hitch and wiring installed after have stated it’s hours of work and like $500 installation. Order for the factory or don’t bother.
reigny
reigny
Karen
Delray Beach, FL
Thanks everyone for your help. I ordered WITH the towing. I'm not sure how my dealer was able to place an order but it went through today and Off Rodeo sent me a confirmation that my order was confirmed.
reigny
reigny
Karen
Delray Beach, FL
This was a really helpful video! Start at 6:30
