Tire Sidewall Cleaner "Recommendations"
BroncoAZ
Mitch
You probably are the only one.
The number one reason that I bought my Bronco was to go get it dirty. My sidewalls are as likely to look like the ones below as to ever be sparkly clean.
I haven’t use the SOS pads on the Bronco in the 15 months I’ve owned it, I’m not a prude with respect to a well soiled Bronco.
The SOS pads seem to scrub off the brake dust buildup on the tires. On relatively clean tires the blue soap becomes a dark brown paste after some scrubbing.
Gtrekker
Gtrekker
Gary
NJ
Yeah, I get it and I'm fine with it normally but, there's a Bronco meet / show that it will be in so I'd like it clean for the ladies...😎
Scott R Nelson
Meridian, ID
If I went to such a meet, I think I would go find some good mud right before and see how muddy I could get it before showing up. You know, to prove it's not a mall crawler. ;)
Gtrekker
Gtrekker
Gary
NJ
Funny... Maybe you didn't catch my build or realized it's a 2 door?
Team 2 Door = Purpose Built and Bad Ass!!!! 🤞🤞:cool:
Gtrekker
Gtrekker
Gary
NJ
OmahaKevin
Kevin
Omaha
2012 Mustang GT, 2023 OBX
Hey, i checked the link. Did you see this and have you had any issues?
NOTE: Do not allow product to contact magnesium or aluminum wheels, painted or glass surfaces, eyewear, fabric and non-rubber items. Permanent damage can occur. USE ONLY AS PER LABEL DIRECTIONS.
I've used it on vehicles with aluminum wheels since the 80s. I spray it on, brush the tire, then rinse. I don't let it sit for long and have always been careful about overspray. I hadn't had any issues. I don't use it every wash. Just when the tires look like they need it
Eroc88
Ohio
Jeep
I use P&S brake buster total wheel cleaner. Stuff works great
Pipper99
Terry
Fort Worth, Texas
2024 Ford Bronco
I picked up some brake buster today. The directions say to spot test first. I have Sasquatch wheels. I assume that it’s ok to use this stuff on those wheels. Pan the Organizer says it’s safe. Have you heard of any issues with brake buster on wheel surfaces?
tonytexchappy
Tony
Texas South Plains
08 Mini Cabrio, 22 Maverick
used to use an APC (OPT power lean specifi) but have a bottle of Gyeon Tire clean I’m about to try.
Eroc88
Ohio
Jeep
I also use this on my SAS wheels spraying the face and the barrel of the rim using a soft wheel brush and just rise it off. It's a non acid cleaner and is safe to use on all painted wheels. It's a good product
