Three-piece top question
MississippiMule
Oxford, MS
2015 Toyota 4Runner, 1976 Ford Bronco
  • Thread starter
  • Banned
  • #1
I’m pretty sure the answer is “no,” but is it possible to use only the two front panels of the 2-door hard top, without the back section? I know you can do the back without the front, as there are many photos, but what about the reverse (top off except shade for front seats)?
It appears you have to have the front lip of the rear section to support the front panels, but hoping there’s a way.
BLTN
Colowado
'23 Badlands; '95 Jeep XJ; '05 F-350; '07 Camry
Nope, sadly - Front panels latch to the rear section...from the B&P 360 view above the driver's seat -
Ford Bronco Three-piece top question Roof Panels
rgwinn
Rod
Salem, OR
2001 Harley Road King
Bimini top.
Erock
US
2018 F150 Alpine edition
Ford Bronco Three-piece top question 1616558030305
don’t know if these are just sitting there or not... but they have side latches on the front two panels, so I think it would still be secure. There are also pics with just the front panels on a two door out there somewhere.
Thed
Ben
Raleigh, NC
'22 GX460 '16 Miata '67 F-100 '21 Streetfighter V4
The write-up from Car & Driver when they did the door/top comparison against the Wrangler noted that Ford stated that you cannot run it down the highway in a "pickup truck" configuration like you described.
https://www.caranddriver.com/news/g35589842/door-roof-removal-bronco-wrangler/
"Both Bronco and Wrangler use similar rotating latches that fix the roof to the body. Both systems are easy and neither has an obvious advantage over the other. Ford did tell us that the driver's-side roof panel must be removed first, which is pretty negligible, as both panels eventually need to be removed anyway. There are three rotating latches on each Bronco panel, with a larger latch on the front outer edges. For two-door models, there are three roof pieces total; there are [four] on the larger four-door. Ford says you can drive the two-door model with the front roof panels off and the rear top still attached, but you can't drive it pickup truck style with the front panels on and the rear roof off. The Wrangler requires removal of the entire rear shell, as the roof covering second-row passengers isn't individual panels, unlike the Bronco."
Erock
US
I stand corrected... maybe worth lookin into making a piece that will latch the back of the front ones when the rear is removed
Adumb
Adam
St. Louis
'21 Area 51 4dr
Yeah wouldn't that be a cool accessory? Truckify your Bronco. A window slider that attaches just behind the 2 front panels. Take everything else off. Yank out or put down the second row. Gladiator killer.
Lowcountry Bronco
William
South Carolina Lowcountry
"There are three rotating latches on each Bronco panel, with a larger latch on the front outer edges."
You should be able to at reasonable speed, it would still be latched at the windshield header but wouldn't be latched to anything once the clamshell is removed. I wouldn't go high speed driving with it that way though, not sure how the unattached rear portion would be affected, might be lift. Maybe the aftermarket might provide a solution but if you have the back off already you've done most of the work and I'd probably just opt for a bimini top as stated above.
TJconvert2.7
I’ve never thought about that but what a great idea. Like a targa top, then if wind deflectors behind the front seats and tonneau covers become available like on wranglers thatd be a sick half cab option
flatlander40
I’m hoping the aftermarket will come up with something for the latches to attach, when the rear piece is removed
Erock
US
I was thinking just a clamp on bar for the rear latches to grab onto. Should be a pretty easy one to make, if I could just get the damn thing here to measure off of... lol
Atomicdog
Eddie
Philadelphia
I wanted to do the same thing but after looking into it I decided to use a Bimini top instead.
Atomicdog
Eddie
Philadelphia
I was thinking of this but then it removed one of the major selling points to me over the Jeep, no bars over my head.
