Thinking About Customizing Your Factory Headlights? Here's What You Should Know
OracleLights
New Orleans, LA
www.oraclelights.com
One of the questions we hear a lot is:
"Do I need to buy entirely new headlights to change the look of my Bronco?"
Not always. While complete replacement headlights (like our Oculus™ Bi-LED Headlights) are the easiest plug-and-play solution for many applications, there's another route some enthusiasts choose: headlight retrofitting. A retrofit is the process of opening your factory headlight housing and modifying it with new lighting components. Depending on the build, that could include:
  • Halo rings
  • DRLs
  • Demon Eyes
  • LED projectors
  • Paint-matched internals
  • Custom shrouds
  • Sequential lighting
It's a much more involved process than swapping an entire headlight, but it allows for a completely custom appearance.
Ford Bronco Thinking About Customizing Your Factory Headlights? Here's What You Should Know Bronco DRL Retrofit
Which Option Makes More Sense?
For most Bronco owners, a plug-and-play headlight is the quickest way to improve both performance and styling. However, if your goal is creating something unique, a retrofit gives you the ability to personalize your factory housings while keeping the OEM look. For example, we offer products like:
These products allow experienced builders to create truly one-of-a-kind lighting setups without starting completely from scratch. We recently put together a guide covering all of this information and more. If anyone's interested, you can check it out here: https://www.oraclelights.com/blogs/latest-news-updates/what-is-a-headlight-retrofit
Not Every Build Needs a Full Retrofit
Many owners simply want a modern appearance without opening a headlight. That's where plug-and-play products like our Oculus Bi-LED Headlights, LED fog lights, side markers, mirror lights, and auxiliary lighting come in. They're designed to install with minimal modification while dramatically updating the vehicle's appearance and lighting performance. Many ORACLE lighting products are designed as direct-fit upgrades for popular Bronco applications.
We'd Love to See Your Build
Have you retrofitted your factory headlights, installed halo rings, or gone with a complete plug-and-play upgrade? Post up some photos! We always enjoy seeing the different directions people take with their builds, whether it's a subtle OEM+ look or a full custom lighting setup.
