Temperature control not responding
Seminole
Florida big bend
7.3 F350 DRW
So I got in my bronco this evening and once I turned it on I had the message that the update was complete. Okay, didn't expect an update but fine. Start driving down the driveway and I realize the A/C was on full blast (showed lo on dial). I tried to turn it down but no response. Turned on Max cool and then off, nothing. Turned auto on and off and still just showing "lo". Passenger dial worked and would change that side but nothing changed on the driver side. Decided to just turn it off. When I did, it turned off the whole truck. Thankfully I was still in driveway with the brake on but was in gear. Just shut down. Hoped it would correct itself after a couple off/on cycles but still stuck on lo and unresponsive to spinning the dial. Anyone else experience this?
TXBronco1313
Honestly I’ve never heard of anything like that. Commenting for better reach. Hopefully someone can nudge you in the right direction but if I were to guess, seems like it may be an electrical issue
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
I’d like to see if I could assist with your temperature control concerns. Can you please send over a message with your VIN and estimated mileage so I can start looking into this on my end?
HeliPilot
Kenny
CT
2022 2.7L SAS
Disconnect the battery for a few minutes. Let all modules reset. Will most likely come back normal.
Seminole
Florida big bend
7.3 F350 DRW
PM Sent
Seminole
Florida big bend
7.3 F350 DRW
Yep, I tried it. Disconnected battery for 10+ (timed) minutes. Did not work. Same thing was happening. When climate control was on it was full blast on "lo" and unresponsive to input on the driver's side dial.
