Temperature control fan randomly stops?
emwolter
Emily
Madison, WI
2023 bronco
I have 2023 big bend and the blower will randomly turn off in both the ac and heat mode. It comes back on after a few seconds. I can’t reproduce it for the dealer so it gets challenging to have it evaluated. Anyone else having this issue?
emwolter
Emily
Madison, WI
2023 bronco
No it happens while I’m driving
HolidayDog
Everglades
MT
24 Everglades
Everglades
If you have the Auto (with 3 lights, 2 lights, or 1 light) pressed or “on” then the ac unit will kind of do its own thing.
I usually manually adjust my temp and fan speed (auto lights are “off”) for my preferences and it tends to do what I want/expect.
Maybe try turning the auto lights so they are off and see if the issue continues or not.
Possible it’s the “auto refresh” feature of your HVAC. To keep your Bronco from killing you with carbon monoxide.
Every 30 minutes or so it will switch out of recirc and pull in fresh air for just a moment. This causes all sorts of shenanigans with the Automatic climate control for some reason
Not sure if that’s your issue but it’s made a lot of folks scratch their heads when it does odd things out of the blue - a lot like you describe
navyaecs
United States
2024 Bronco Wildtrak
The fan also slows down when you have an incoming phone call over Bluetooth. Related?
