Swapping Sasquatch Fender Flares for Standard Flares?
ericwayne
1969 Bronco
I haven't seen it mentioned (I did search), but I should be able to easily swap the Sasquatch fender flares for a standard set....correct? That would eliminate the really wide flares and have a better stance. Thoughts? Not sure I would want to change the shape via aftermarket, just the width.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Oh my god. Yes.
They are so easy to swap, you could probably just pull up to another bronco at a stop light, hop out and swap them over, and get back in and get away before the other person realizes what's happening.
Catmandu
SW Florida
2013 Jeep JKU (Officially Sold), 2015 Expedition
This is my plan, should be a <5 min mod.
Balthezor
Ronnie
PA
I would love to do this as well. Never had a vehicle with tires past the fenders. I'm guessing more dirt and rocks on the side of the vehicles? More damage?
MileHighCitizen
Al
Denver
Bronco 2D 2.7
The fender flares serve a purpose, they help stop debris from being shot at the car behind you and protect the side of your vehicle as well. If you put smaller ones on and your tires stick out, I hope your windshield get broken before you break somebody else's.
Escape Hatch
Mk7 GTI, 19 Atlas SE w/ tech R Line V6 4 motion
Looking forward to seeing other future aftermarket options as well.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
kodiakisland
Arkansas
Oh my god. Yes.
I imagine more than one person is going to find theirs missing, even when parked for a few minutes.
Monster79
E
Alabama
15'Stang, 07'F150, 23',96',93',79'Bronco
If you can't find anyone. Ill be your huckleberry.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Anyone here with experience know if doing so will make a lot of dents in your paint (due to small rocks) on the side of the car?
Do you mean having your wheel treads exposed outside your fenders?
I mean, yeah. Your tires kick up all sorts of stuff and without fenders/flares to catch it that stuff has to go somewhere.... but it will be traveling more or less in a plane parallel to the side of your vehicle... but still against your vehicle.
Ford Bronco Swapping Sasquatch Fender Flares for Standard Flares? Aetna 8-1 9.JPG
Bronco21fan
Angelo
NewJersey
The wider flares for the Sasquatch are made wider to acomadate the wide tires you put reg flares on you will have rock chips out of the asshole on your vehicle
DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
Yep. Anyone considering doing this or aftermarket, pushing the wheel and tire out more....check your State's Laws on how much of the tire must be covered. Also know if you throw a rock and damage someone else's vehicle....you are liable.
