Suma Performance Mirror Question
fftfk
Naperville, IL
Basesquatch
Hi - I have two questions that I have not been able to find answers to.
  1. My base model came with a little convex section of mirror separate from the main mirror. It looks like it is not part of the standard mirror assembly and it does not move. Does the Suma mirror work with that?
  2. I know they are convex horizontally. Are the convex vertically as well? I have a very narrow car lift I back my bronco onto. It would really help to be able to see where my rear tires hit the ground for backing up purposes. I've added a photo to show the ranges I'm working with.
Ford Bronco Suma Performance Mirror Question tempImage2YheXg
Yes - I know...I should have measured the lift platform against the measurements of the Sasquatch package before buying! Lol - the other side is not as bad. In total I have about 2 inches of room to get on the platform.
WheresMyBronco
Los Angeles
2023 Badlands
I don't remember how the OEM mirrors were to compare the two, but with the way my Suma mirrors are setup right now I'm not able to see my rear tires on a 4 door w/ sasquatch. I'm sure if you angled them downward you might be able to but I didn't get a chance to check.
Can't comment on #1 though, maybe @Suma Performance can
WheresMyBronco
Los Angeles
2023 Badlands
Just checked and if you angle your mirrors down you're able to see the bottom of your rear tires, so if you're okay with doing that each time you get on the lift then you might be good to go.
