Steering Sensitivity Adjustment?
Pygmy Warrior
Georgia
2024 Bronco 2.3L , 2023 Bronco 2.7L
Is there any way to adjust the sensitivity of the steering? Mine seems overly sensitive.
Moto26
Tucson AZ
Put it in Sport mode?
Headsong
Are there tears? (sorry...couldn't help it)
What did you used to drive?
MNBigfoot
MN
This. I believe a couple other goat modes do it also. But at the same time they are changing your shift points (auto). And the Bronco defaults back to normal after shutting it off (unless you okay upon Start up).
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
LOL, It definitely seems sensitive after I drive my 87 Squarebody where it has roller ball steering with super slow ratio and the steering wheel moves an inch either way to make normal corrections. The box is brand new and tight too but not rack and pinion like the Bronco. I like the steering in the Bronco way better, BTW.......
Moto26
Tucson AZ
Also, if you still have your stock Big Bend tires on it, upgrade to some 34” A/T’s and it’ll slow down your steering, too…
