Standard vs. Signature Lighting
Rick Astley
Up Doug's ass
d
"Signature LED Lighting", as far as I currently understand it, is the front headlights, not the rear taillights. I have not seen anything put out by ford which listed "signature" lighting to be a set or reference taillights at all. Was under the impression that's the fancy bar through the headlight being one unit.
Rick Astley
Up Doug's ass
d
It's certainly as clear as most likely clarity might want to be.
Which is to say "it is not clear at this point".
Full disclosure: I do tend to assume that something is not true unless proven to be true. That they specifically said "signature LED headlamps" only means to me that the headlamps are LED, not taillights.
And that unless you have BLIS, you're getting incandescent bulb tail lights. For over a decade cars would have the HID headlights as an option and eventually standard, all the while tail lights were incandescent.
BLIS is pretty nice in the Ranger and the LED tails look good on Bronco. If I was planning on off-roading as a primary hobby, I would be apprehensive about BLIS tail lights due to cost of replacement as they stick out. As it will be just a side-hobby for me and something done a few times per year, i'd spring for the BLIS and roll the dice on needing replacements!
Bronc-O
Phoenix
2021 Lincoln Aviator
The signature lighting is in the headlights. It starts with Outer banks. If you look at the fronts of the models, you'll notice the light tube extends in front of the headlamp. That's signature lighting.
zrizik99
Zach
F150 2016
Did you confirm that LED taillights come on the mid package? My dealer wasn't able to confirm it.
Rick Astley
Up Doug's ass
d
It would be the Signature lighting which isn't a Mid Package item, you will need to select a model which has Signature lighting standard or as an option. You didn't list what model you're after.
Taken directly from the B&P you get this info on Signature lighting:
Ford Bronco Standard vs. Signature Lighting 1613524664961
zrizik99
Zach
F150 2016
Thanks man
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Thanks man
As Rick said, you have to select Signature Lighting either as standard or an option... but we have confirmed LED taillights are included with “Signature Lighting”
Bandit958
Larry
Bad Axe, Michigan
77 Bronco, 2021 F150 4x4 Sport
Vinyl doesn't breath so feels even more uncomfortable than leather when it gets hot.
Got my BD and the vinyl seats are awesome, they feel more like leather. if that answers any questions
