- Chris
- Feb 1, 2022
- 16
- 743
- 812
- DFW, Texas
- '23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
- Wildtrak
I went to AutoZone and got ~3’ of hose (take connector/hose with you)and swapped 2 of the connectors around to extend the hose length. I removed one short length of hose, took the connectors from it to use with the new hose. I actually used the new hose to drop behind the grill from the top of the core support, then connected the original long hose to it, but you can do it either way. You can pull the connectors out of the existing hose without destroying it if you go slow. This is the best pic I have of it after swapping the connectors around and extending:Do you mind explaining what you did for the sprayer? After my install, I’m left with these two ends…trying to figure out if I just need to get generic hose and/or what to do with these ends to make it connect.
This length gave me some play to route around the winch, but I probably could have shortened at least 6”…
