Spare Tire Cargo Basket
ChapEJF
Everett
2021 Bronco OBX/BD Mashup
I have switched my order to a soft top so I am interested in a spare tire cargo basket for the Bronco. Has anyone seen one produced as of yet and if so what vendor? I am sure they will come along at some point similar to this one for the Wrangler. Thanks,
Ford Bronco Spare Tire Cargo Basket Spare Tire Cargo Basket
JaxGtc
Ford Bronco Spare Tire Cargo Basket IMG_3648
Is that a whole new tailgate bolt on carrier or a retrofit for the existing on the Jeep? Here is a pic of the bronco that I had from Austin.
ChapEJF
ChapEJF
Everett
This one and most that I have seen are a bolt on to the existing tire carrier. That is what I am interested in. Thanks,
BroncoKong Jr.
Andrew
Nobody's making them yet. How much can the Bronco swing gate carry? I have a feeling it's pretty low with the larger factory tires.
ChapEJF
ChapEJF
Everett
That is what I suspected. Not sure how much the swing gate can carry but I do suspect we will see an upgraded setup to carry more weight, or at least I hope we do. Thanks,
ChapEJF
ChapEJF
Everett
RucRak has an interesting solution. And an option to use the trailer hitch for weight support. They'll be coming out with a Bronco version soon.
Thanks, I took a look at the Rucrak and it should be interesting to see what they come up with for the Bronco. One concern with their current setup is blocking the rear camera. I will check back to see what they come up with, thanks.
WuNgUn
Ontario Canada
2 door Squatched
They have an interchangeable center plate for camera use 👍🏻
BroncoKong Jr.
Andrew
That looks super cool. But I wouldn't want to open the gate after loading it.
Ideally I'd like something like that but goes straight to the hitch. Use a Yakima BackSwing (or similar) with it.
Although at some point hopefully Ford or the aftermarket will come up with a swing gate reinforcement.
Wandering Hiker
Paul
Atlanta, GA
13 CMAX Energi
I've been looking for a solution like this - if only to hold wet life jackets and broken down kayak paddles (or nasty sweaty clothes after working out) outside of the car. It doesn't need to carry Aunt Edna's dead body, though.
Tears5150
Pete
Danville, CA
Tacoma
I just found a pretty cool solution. I'm not sure if it would ever have a long term affect on the spare tire, but considering the weight limitations, tailgate clearance issue and back up camera location, this might be the best we're gonna get for now.
The company is called American Adventure Lab and they're located in St George, UT.
https://americanadventurelab.com/product/mass-spare-tire-platform-stp/
Ford Bronco Spare Tire Cargo Basket 1643666024678
There's also a mounting bracket option that you can put on each side for jerry cans and recovery boards.
Ford Bronco Spare Tire Cargo Basket 1643666070954
