Sound System Upgrade Question
Laminar
Iowa
Cougar
That may be true, and I won't debate that info. However, there is an intrinsic "enjoyment" value of having the options while owned. Meaning - If I have all the options, I will enjoy having them available to use.
Yes, my wife enjoys having several different purses available to use.
That I lost value at the time of sale likely won't be that much of concern.
An enviable position, to be sure, but the opposite of your original claim.
The F150 is Fords flagship so it's understandable the lower trim models would hold value as they make a perfect "work" vehicle.
"The Bronco is Ford's flagship offroader so it's understandable the lower trim models would hold value as they make a perfect "offroad" vehicle."
Platinum model is the "mall crawler" version.
"Badlands model is the "mall crawler" version."
As for the Bronco we may be looking at apples and oranges - Bronco is billed as purpose built - to take on Jeep.
"F150 is billed as purpose built - to take on Chevy/Dodge."
The analogy is very close. The vehicle inherently has some utilitarian value. That utility doesn't really go away with age. But people that are buying Platinums are not buying just the utility, they're buying the gizmos, the gadgets, and the prestige of a new, fancy truck. The money you pay for the "new" and the "fancy" is what evaporates right away.
In the same vein, the Bronco has some base utility that will always be there. Those that choose to pay twice as much to get some flashy wheels and bigger screens and branded speakers aren't doing it for the pure utility, but for the intangibles that come with it. And the intangibles aren't worth as much on the secondary market.
P.C
Paul
2005 Silverado, 1952 Chev 3100, 2016 Honda Fit
I wasn't surprised Ford did not make B&O a stand-alone option. Car companies make much more money when they bundle options into packages.
Same reason Homelink isn't available by itself. That's one option I really wanted because otherwise I'd need to have three remotes clipped to my visor to get into my community and garage. Ugh.
Still don't think I will pay $6k for the LUX pkg though.
Look up Homelink garage door opener on Amazon. $150 bucks install yourself, skip that $6000 Lux
Economisto
Houston
2000 Mistubishi Montero, 2013 Audi S5
Pretty sure all of the B&O speakers are just cheap paper speakers with Ford stamped on the back. As a F150 owner with the B&O option, I can tell you that there's nothing hugely special about the B&O speakers.
That would be sad if B&O allowed themselves to sell cheaply made stuff. Back when at least, they were not only high end, but like one of the highest you could get. LIke doesn't make sense financially even for millionaires high. I have a feeling the speakers themselves are actually solid along with the amp, Ford prob just doesn't take time to calibrate them to the vehicle like Audi and other luxury brands do.
JAC
Joshua
Oregon
2018 Toyota Tundra; 2020 Acura RDX
As does Mine....
For now, as we honestly don't have any info to go off of, I will keep my opinion that a used fully loaded BL or WT will hold a greater value than say Base model.
Yes, the Bronco will be Ford's flagship off-road vehicle - the trip level part is debatable... I say this as (from what I can read from this forum only) there are two main buyers here - fully loaded from factory (BL/WT/OBX) i.e. folks that want all the bells and whistles and might add "some" options later and (base/BD/BB) folks that want to fully customize on their own with OEM and nonOEM parts to build "their" personal off-road monster.
Yup, not going to disagree here.
This has always been the case for Ford Trucks. no denying that.
This may be true - again not debating the issue. I guess we will have to see what a few years down the road look like when if comes to revisiting the topic. Cheers and Thanks for the conversation.
Wolfeman
Little Rock, AR
2019 F150 Raptor
Oh... Oh, no. No, no, no.
Harman Kardon has some of the best auto systems in the market. Can't believe you replaced it with an :sick: Alpine. ?
Alpine's ? quality in the auto market has become basically Walmart level in the last 15 years.
I feel for you, man. Oof.
That being said, I have zero experience with Bang & Olufsen but I do know they've been competitors with Harmon Kardon, Bose, Lexicon and other high end systems.
I don't know if they're worth the money for the Lux Package by themselves, but you're getting a LOT of other things with that package that smooths out the overall cost.
If I end up unhappy with my B&O system, I'll do as I've done before and pull it out and replace it with Harmon Kardon or Bose.
Pretty sure Harman Kardon owns B&O
https://news.harman.com/releases/ha...on-of-bang-olufsens-automotive-audio-business
Wolfeman
Little Rock, AR
2019 F150 Raptor
Here are some pics I stole from another forum where a user upgraded his B&O system using Focal components. Gives you an idea what you are getting with the B&O. It sounds fine but it's by no means an audiophile system.
Ford Bronco Sound System Upgrade Question 2B7AB096-64B3-4C82-937D-926461AF6416
Ford Bronco Sound System Upgrade Question 7364EF00-5AFB-4D72-A6DB-EDBBC76245BC
Ford Bronco Sound System Upgrade Question 510B845F-9E6E-44E5-92BD-C2ED73A225D6
Economisto
Houston
Those are all focal speakers, did you find photos of the B&O speakers after they were taken out?
Edit: Ohh the mid picture is the stock B&O correct?
Wolfeman
Little Rock, AR
2019 F150 Raptor
Top picture shows Focal speakers with magnet up but the cone up are the B&O speakers. You can see the cone material and surround.
Middle picture is the magnet of the front (6x9) and rear (6.5).
Bottom pics are of the A-pillar mounted tweeters - stock vs Focal
Economisto
Houston
I don't see much difference between the two. I think its time i go listen to them at the dealership.
ericmario
Toronto
2017 Mustang Ecoboost Premium
You can add $500 in aftermarket speakers to stock system and it will blow the B&O away. Not being negative, but every B&O Ford I've heard is terrible. Full disclosure, my wife wants Lux and I also am preparing to have to throw the B&O in the garbage and put quality stuff in.
Dibs! haha
xXChartmanXx
Ford Explorer, Honda Pilot
Lol, other then the magnet being at least 10 times bigger and the much nicer cone material. Trust me the B&O is not going to sound close to a properly amplified Focal speaker set. That being said, some people are not audiophiles and could care less about the quality and accuracy of the sound, and that is totally OK. I was an assistant manager at a theater in college and ran the projectors all the time. Every time I go to the theaters (Or should I say back in the day when we used to go to watch movies, f$%k you COVID) if the film is slightly out of frame it triggers me to know end. I start to get up to go tell the employees and my wife starts laughing. No one else in the theater even knows its off frame, but i'm triggered by it lol. Same goes for audiophiles. What some people hear and think "sounds fine man", the audiophile is cringing and wanting to cover his ears because the treble is shrill and unrefined, the mid bass is almost non existent, and their is no deep bass at all, and that's ok too. The normal person is gonna think the B&O sounds great, the audiophile will always want better.
Gpscharron
Claude
Waynesville, NC
2021 FORD Bronco, RV- Ford E450 (Thor Vegas 24.1)
Good tip. Any suggestions in regards to aftermarket speakers?
Economisto
Houston
Lol, other then the magnet being at least 10 times bigger and the much nicer cone material. Trust me the B&O is not going to sound close to a properly amplified Focal speaker set. That being said, some people are not audiophiles and could care less about the quality and accuracy of the sound, and that is totally OK. I was an assistant manager at a theater in college and ran the projectors all the time. Every time I go to the the:LOL: aters (Or should I say back in the day when we used to go to watch movies, f$%k you COVID) if the film is slightly out of frame it triggers me to know end. I start to get up to go tell the employees and my wife starts laughing. No one else in the theater even knows its off frame, but i'm triggered by it lol. Same goes for audiophiles. What some people hear and think "sounds fine man", the audiophile is cringing and wanting to cover his ears because the treble is shrill and unrefined, the mid bass is almost non existent, and their is no deep bass at all, and that's ok too. The normal person is gonna think the B&O sounds great, the audiophile will always want better.
I obviously have no idea what a good quality speaker looks like on the inside :LOL: but i'm def an audiophile. It's really hard for me to enjoy music now if its not well balanced and crisp. Worst case scenario ill have 10 speakers i can swap out instead of 6 for an even better aftermarket system! RIP my wallet
