Soft Top Left Hand Part # for Latch
sinning
C
Conneticut
2022 Bronco Black Diamond V6 2.7L
Hi everyone,
We recently bought a new soft top from a different forum user, as our old one was bent (made a whoopsie keeping it down while trying to park in the garage). The problem is, the roof lacks the latches on RH and LH sides so we can't secure it. (pics below). I believe the part number to the latches is here: M2DZ-78502G70-AC - Clamp 2022-2023 Ford Bronco | Ford OEM Parts Direct, but it only lists a RH side part. There doesn't seem to be a LH side part.
The question is, is there a LH variant or part #, or is the RH side part number the exact same as the LH? If someone happens to have the LH part # could they please post its designation?
Thank you!
Ford Bronco Soft Top Left Hand Part # for Latch processed-79FF23C3-CA57-4DBB-8F24-9D858F421580
Ford Bronco Soft Top Left Hand Part # for Latch processed-900CB7DD-3507-4707-9575-EBF8403B44EB
sinning
C
Conneticut
Thank you so much for your reply! If you could check the part/part #'s that would be amazing. I'm with you - I assume they're the same but just listed only as RH for whatever reason.
They look identical to me - 3 screw holes, 2 alignment pins on either side. I can’t pull the top back to look closer since it got covered in snow last night to check and make sure the alignment pins are the same - but worst case they are threaded and you just swap their position.
sinning
C
Conneticut
Thank you so much! I'll report back once we order the parts and get them installed (or attempt to! :)).
