- #16
I did not attempt to update the APIM, I did however put the latest update to the PCM via FDRS and that did not fix it. I am going to take your suggestion and leave it alone. No sense in making a problem. Any idea why ForScan shows the module but FDRS does not? Thanks for the help.At most, make sure the FDRS is at the latest level. If not was not when the last programming was done there's an outside chance that was the cause. The pinpoint test for that specific code, assuming no other contributing factors, basically is circular. That means it says fix all other codes or faults first, make sure FDRS is up to date and try reprogramming the module (PCM) and hope it disappears.
By the history, I can't tell if you actually attempted the APIM update which requires a formatted flash drive to complete.
