Snow covered headlights fix?
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
That's be a really good solution. I'm not sure I'd want to use an Aux switch for it, but I'm sure there is a way to tie it in somehow. There are so many smart people on this forum, this would get solved in minutes. It just needs to be developed.
maybe tie into rear defrost?
dingle87
Reese
West Suburbs of Chicago
2019 Ford Explorer XLT
That's what my thought was too, since if I'm using rear defrost I'd probably need the lenses defrosted too. I just don't know the logistics of tying them in together. I'm sure it's possible. Now we just need the product. LOL
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
It would be especially easy for soft top rigs since they have a plug in the rear.
jolson1228
Jon
Ford Bronco
I'm sure that if someone made a product like that, you could tie it in to the same wires that run heated mirrors/rear defrost with a splice or waterproof wiretap. Maybe @Mabett could make something, they have some good solutions for other problems!
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
What about using deicer fluid when needed?
Or
Possibly a DIY solution using heat trace around the housing behind the grill and tying it into one of the Aux switches. This is the route I would go. Unless the aftermarket comes up with something reasonably priced.
MNBigfoot
MN
Or perhaps Ford could use technology that's worked for the last 100 years...... Non-LED headlights.
emulous74
Seth
Austin, TX (Pflugerville)
'19 ZR2 Bison D , '23 Bronco 2DR, MT
Most luxury vehicles have done away with the wipers and now they have high powered jets that shoot windshield washer fluid on them. Shouldn’t be hard to take them off a junked vehicle and retrofit on the bronco. Does the front camera already have that?
