Ski Rack options / solutions?
Montana Bronco
Montana
Chevy
Thule rack from my 2009 Subaru, fit fine on my Bronco.
Ford Bronco Ski Rack options / solutions? IMG_6705
batmanskier
Will
2021 Bronco 2 Door Sas
With our full roof rack, you can still take the front two panels off as well as the middle panel. You can mount the Yakima FatCat Evo line or the Yakima FreshTrack line on our rack. The Yakima SkyBoxes will also mount up to our rack if you do not want your skis/snowboards exposed to the elements!
Do you have measurements on how high the FatCat is off the roof when mounted to your rack. I have about 7-7.5 inches of clearance to work with.
TrailRax
Lux Sponsor (Level 2)
TrailRax
Woods Cross, Utah
www.trailrax.com
2023 Bronco Badlands
Unfortunately, we do not have the height measurement of the ski racks themselves. Our rack will add about 3.845" of height to your Bronco. Yakima may be able to answer the question of how tall the racks sit off a crossbar!
Rocket Surjin
Sierra Madre, CA 91024 USA
2009 Honda Ridgeline, 2024 Bronco Wildtrak 4D, 2018 BMW M240 Coupe
Easiest way to spot a flatlander with no clue is having their ski/board equipment exposed to magcloride and road salt on a rack.
Exposed ski gear is the best way to trash your edges and wax job. Get it in a coffin box, a gear bag, or put it inside the rig.
Take care of your gear.
Digging up an older thread as ski season is again approaching. I never bothered to get skis, just boots, so I don't have the knowledge that some of you have, but I wonder why you don't have the solution that cyclists can use when they need it? Maybe the material is too porous to protect from road spray. (stock photo of a bike sock)
Ford Bronco Ski Rack options / solutions? 1725413253583-1
northernlights
Durango, CO sometimes AZ
2024 Ford Bronco
my issue is my garage threshold height will NOT allow a Rack AND a box on top. Barely will fit a ski rack on the rack. So the ski's will go inside the cargo area. But I don't like them sliding around. I need a better way to secure them in there. Ideas?
