Shh- Don’t tell Ford—OEM Roof Rack on 2.7 Badsquatch
kbobber
Kevin
Tiburon, CA
VW Touareg & Atlas
Ordered and installed OEM roof rack for my 2.7 Badsquatch. Bestop Bimini also installed under roof! I like the ability to still be able to remove the front roof panels with Bimini and roof rails!
Definitely “compatible!” Not in compliance with GVWR….yeah right…..😬😂
Desert_6G
Phoenix, AZ
Ranger
Is there any road noise from it?
Marauder
Josh
St Louis
MNBigfoot
MN
Price and Build shows Badlands can be ordered with Sas and the roof rack.
pan-y-cerveza
Manitoba
Tacoma Pro
You weren’t under the concession that there would be something that would not allow you to bolt that on correct? Once it’s in your possession you can modify it as you see fit. They just can’t build it for you that way for liability reasons.
You weren't under the impression that this wasn't a tongue-in-cheek post were you?
Rusty Sheckelford
Rusty
LA
He feels he cheated the system, the only one he cheated is himself or the occupants of his vehicle. I fully agree with do as you please to your bronco, just as all onboard are aware. Ford’s engineers and lawyers have a little experience in this automobile manufacturing thing.
Avatar checks out.
Octavian7896
Andrew
Mulvane ks
21 Bronco 4D FE CG
kbobber
kbobber
Kevin
Tiburon, CA
VW Touareg & Atlas
Tks Green Diamond…I think I will be ok “hauling” my surf boards out here in CA and won’t be exceeding the approximately 860 pounds (lower limit) of allocation (GVWR is 6,180 lbs and the estimated curb weight of a 2.7 Badsasquatch is 4,661 - 5,320 lbs). Just gotta do the math and not generalize…
BroncoKong Jr.
Andrew
Presumably you also post this in the threads where people add PPF or a bull bar?
TX_Bronco77
Travis
Earth
2018 Mustang GT PP
I bet you even tore the tags off your mattress you filthy rebel scum!
tourproto
Portland, OR
2004 BMW e46
Nice! I will probably do this in the summer for my BL. I just don't wanna deal with rain in the cabin even though I have the MGV seats and wash out interior.
I wasn't sure if the Bimini and roof racks were compatible. Nice to know they are.
Baja71
tw
Dallas, TX
1971 Stroppe Baja Bronco
You were right! Look at what happened!
Ford Bronco Shh- Don’t tell Ford—OEM Roof Rack on 2.7 Badsquatch E02D65AE-F0EF-4A4E-AB58-76DBF9096173
