Scuffs to interior plastic
stickshifthappy
RVA
Ford Ranger, 65 Mustang
Your use off the word hard plastic is interesting. I'd say there's nothing hard about the plastic interior.
In fact it's incredibly soft, and cheap. It's my single biggest complaint about the Bronco to date. I'm amazed that they used such an inferior product. The slightest brush against the surfaces leaves a mark.
I believe I read a post here that stated you can ceramic coat the panels for some added protection.
Area51BS
Ron
Badlands non SAS 4dr 2.3
It’s a Ford issue. I believe they use recycled plastic bottles. The Maverick is the most worthless POS when it comes to plastic. It’s my biggest gripe with Ford besides CarPlay. If not gouged you can use Griots 3 in 1 ceramic spray while cleaning to help conceal that white look. Or apply heat carefully. Practice somewhere inconspicuous. It works.
Sandbergo
Jelani & Dave
Orlando
Rogue
I believe that the marking comes from it being textured, so it’s likely that the textured part is less robust than the base of the material. I’m not really sure what people would have preferred, a leather or pleather wrapped door panel that would likely be hell to clean after a good dirty day or maybe some suede? If you are careful you can likely use a heat gun at a distance to help a little but be careful not to burn or melt the panel. As for people wanting more, why not take your door panel to the nearest automotive upholstery place and ask if they can do anythjng.
BadlandsA51
Craig
Kansas
23 Badlands, Sasquatch, Lux Pkg, 72 Ranchero GT
Has anyone found a way to buff out scuffs on the hard plastic interior areas of their Bronco?
I don’t know anything that will get rid of scuffs, but going over the plastic with 303 seems to really help to prevent the scuffs from happening in the first place. I like 303 because it’s not greasy and won’t attract dirt. It makes the plastic look nice, too.
stickshifthappy
RVA
I don't agree. I believe the marking is a by-product of it being incredibly soft. I've had 2 Tahoes with textured interior panels, and they didn't scuff like this.
Recycled plastic sucks donkey balls. Once you recycle plastic it loses chemical properties that makes it less durable, and it breaks down much easier.
  • Like
Reactions: 0ne
blessedx4
Which 303 do you recommen?
Sandbergo
Jelani & Dave
Orlando
Rogue
I doubt the texture was the same but it doesn’t matter in the end, the panels scuff and scratch and I suppose they should have made a trim with the “mall crawler” in mind that would have a luxury style interior instead of the dumbed down that everyone has. Have you been in a new Toyota lately? Seems more and more manufacturers are switching to less expensive interior materials but still charging a premium. As for ceramic coatings they will make it easier to clean but they aren’t going to make it more robust and stronger. I am still waiting for someone to have their panels redone.
stickshifthappy
RVA
Whether the texture was the same or not, It's the durability of the plastic that's the issue. It's cheap.
0ne
Nate
CO
Flex
Magic marker touch up (y)
Sardine
2022 Elantra N - 6 speed & 2023 Badlands
Ceramic coating wouldn't help at all, actually. It's a common misconception that ceramic coatings even protect against scratches on paint.
The only thing that might help is applying Aerospace 303 as it rejuvenates the plastic so it doesn't look so dry. Which should help hiding small scratches.
