Sasquatch wheels
Sheldor
Kansas City, MO
Not a huge fan of the Sasquatch wheels but when the mpg is almost identical it’s hard to not just add it on to the BL. I don’t want to add 35s later or adjust the suspension to the stock BL, personally I like it being covered under warranty and having the proper gearing and whatnot. Anyway, is it possible to fit the BL optional wheels into the Sasquatch package? I’m assuming no, but don’t know what is and isn’t acceptable wiggle room when fitting a tire to a wheel, there’s also a different offset too. Thanks.
Apologies if this has been asked, I can’t find anything in the search.
Chrism81
chris
connecticut
Mazda
I saw the sas tires today and I like them. They are big, but I wanted sas upfront because it would be easier to go down to 33" then to do the opposite. I wouldn't go any lower than 33". I don't think it would look good. Looking at BL and sas today I really couldn't tell the difference. They are both freaking big and look good. I don't see why you couldn't fit the BL on a sas bronco.
UncleBuck
Washington
2011 Ranger XLT 4.0L - 4x4
The forged aluminum wheels on the raptor are the same size as the Sas wheels and they look amazing. Might be worth trying to get a set of those, plus I think they’re lighter.
reidski29
Reid
Grand Rapids, MI
2013 Ford Expedition, 2018 Santa Cruz Blur
I am with you. I am getting the SAS package as I really want the offroad goodies that come with it (lockers, suspension upgrades, and larger tires). However, I may not keep the same size tires for the second set - either go with 33's or 34's? I also definitely want a black beauty ring!
Montana Bronco
Montana
Chevy
wrong bolt pattern
Raptor911
Raptor911
Broadlands, VA
Raptor wheels are a different bolt pattern and thus will not fit the Bronco.
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
The easiest way around this would be to trade for the wheels you want after the fact. BUT the optional wheels are a 17x8+55 and the Sasquatch are a 17x8.5+30. So in order to clear components with those 315's you would need to bolt on a 1" spacer with the 17x8's
Raptor911
Raptor911
Broadlands, VA
spice it up sir. Black wheels with Black rings are boring. It just blends in with the tire and you can't tell what is what.
Does this look good?
Ford Bronco Sasquatch wheels 1621282204521
The Sas wheels will look great once the beauty ring is swapped out to black.
VelocityBrew
Honestly? No. Coming from a KTM owner too.
Stache12
Wisconsin
Ford Explorer, Chevy Cruze
I have to tie it in to something else on the truck. If there were orange on the truck to tie into that beauty ring I'd be all about it.
