- First Name
- Mark
- Joined
- Feb 15, 2022
- Threads
- 59
- Messages
- 1,221
- Reaction score
- 1,652
- Location
- San Antonio, TX
- Vehicle(s)
- 2020 Hyundai Palisade
- Your Bronco Model
- Outer Banks
So to the original question, the value of the Sasquatch package.
Excluding the Badlands (or package which comes with the sasquatch package standard). The Bronco's capabilities on non-sasquatch Broncos is reduced depending on the trim and configuration. Upgrading the differential(s), transfer case, suspension, wheels, and tires via the sasquatch package is anywhere from a good value to a great deal, as long as you want the whole package.
In the Badlands - it isn't a good or great value, UNLESS you want the Sasquatch rims and tires.
Personally, I didn't want to run 35's, 4.7's, and I didn't like the rims or tires with the Sasquatch package. I wanted lockers, but I also wanted carpet, a cloth interior, and adaptive cruise control. I was somewhat screwed and had to decide on what compromise I would accept.
In the end, I ended up ordering the OBX with the rear locker, advanced 4x4 transfer case, and lux package. The 4.27 locker is plenty to run 33.5" tires even when running around Colorado (above 7,000'). I didn't get the sway bar disconnect or the front locker. I was initially bummed that I couldn't get everything that I wanted, but in the end, I was happy with what I ended up with.
The advanced 4x4 transfer and rear locker only added $1500 to the price. The 4.27 will run a wide range of wheel/tire combinations with ease. I addressed the suspension "short comings" by installing the Badlands shocks and springs. I have wheels and tires that look amazing on the Bronco (plus an extra set of wheels/tires for highway/economy use - 23 mpg at 70+ mph). It has been brilliant for the 41,000 miles that I have put on it so far.
Pikes Peak 14,000+ elevation.
I don't regret that I went non-sasquatch, but I also realize that I sacrificed some capabilities and some resale value making the choices that I did.
Tell me more about what's on your front bumper there.
I also have the factory plastic bumper coming (because I wanted the fog lights and wiring all done from factory). What have you done with yours?
