Sasquatch beadlock rings from KMC
TJ
Wayne, MI
Liberty CRD, Aveo
Just fyI, as an alternative to the ford performance beadlock rings, im 95% sure kmc rings will bolt right up to stock squatch wheels. I unfortunately mounted the tires on the kmc wheels before I had a chance to actually try bolting them onto the factory wheels but as you can see in the pic all the holes lined up which follows that the hidden holes also will.
Ford Bronco Sasquatch beadlock rings from KMC 20220716_081819
tjdeerslayer37
TJ
Wayne, MI
Liberty CRD, Aveo
These are from kmc grenade crawl wheels btw
illverado
Cory
700whp stick shift 2000 silverado 23 basesquatch 2dr 7mt
You HAVE to try actually mounting one! Those are a good bit cheaper than the fords. And I like there’s multiple styles available too. $128 each for machete style from summit and $113 for these from northridge!
FatRat250
Easton PA
22 Bronco Badlands Squatch Lux Hot Pepper
I had these KMC Grenades on my Jeep - my beadlock rims were stamped “off road use only” which was an issue for state inspection - just an FYI. it is engraved deeply on the trim ring. I know KMC makes a true beadlock (which I had) and a fake beadlock - so maybe the fake trim ring isn’t stamped ? I can see it in your picture when I zoom in.
Copperhorse73
Justin
Mooresville, NC
I have an old spare set of Dirty Lift rash rings from their Dual-Tek series and just checked, they line up just fine
tjdeerslayer37
TJ
Wayne, MI
Liberty CRD, Aveo
These are true beadlocks, no inspection in Michigan so I hadn't considered that for others
FatRat250
Easton PA
Destroyer
2002 Chevy SWB NBS, 2022 Bronco
Any update on this? Would love to be able to pickup some KMC rings with the drain holes to be able to use on the factory SAS wheels if possible
  • Like
Reactions: cbs
tjdeerslayer37
TJ
Wayne, MI
Liberty CRD, Aveo
I sold my squatch wheels, but don't see how they wouldnt fit, all the bolt heads lined right up
