RTR Front Bumper Light Mount Kit for BRaptor!
Status
Not open for further replies.
RTR Vehicles
RTR
Concord, NC.
www.rtrvehicles.com
Bronco RTR
The RTR Front Bumper Light Mount Kit with (2) PROJECT X HP.70 Lights are now available for the Bronco Raptor!
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! IMG_9102-2
This kit includes (2) powder-coated light brackets that mount directly to your factory BRaptor front bumper and (2) PROJECT X HP.70 Lights. These lights have an output rating of 15,000 raw lumens. They feature PROJECT X's signature running light design that you can see below.
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! IMG_9160
Also included with this kit is a wiring harness that allows you to seamlessly wire up these lights to your AUX Switch panel. If you already have the RTR Lightbar with PROJECT X FF.70 lights, these pair perfectly with that setup.
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! IMG_9108-2
Below are images of the lights on.
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! IMG_9152-2
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! IMG_9142
If you would like to learn more about the RTR Front Bumper Light Kit, visit the LINK. Thanks for checking out our latest product for the Bronco Raptor.
sunpro2010
22 Bronco Raptor (9-7 build day)
Can I buy just the brackets? I have those lights already, bought them before the Braptor arrived.
RTR Vehicles
RTR Vehicles
RTR
Concord, NC.
www.rtrvehicles.com
Bronco RTR
Hey! We can sell the brackets, hardware and harness. If you would like to get this in motion, send an email to [email protected]. Mention in the email that you chatted with Jaron on Bronco6G.
sunpro2010
Spooled
Republic of Texas
Raptor, Model 3
@RTR Vehicles I know it's hard to get accurate night shots, but could you guys post a few with the bumper lights on to show the illumination they provide?
RTR Vehicles
RTR Vehicles
RTR
Concord, NC.
www.rtrvehicles.com
Bronco RTR
Sure thing, this is Vaughn's personal BRaptor and as soon as we have access to it again, we'll grab some and share with everyone!
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
I just got finished installing this kit a few minutes ago and wanted to give some honest feedback.
I’ve installed quite a few lights on vehicles over the years and I gotta say, the instructions and wiring harness that come with this kit are the absolute BEST I’ve ever used. Well done RTR and thanks! Took me an hour from start to finish.
This is the first pair of Project X lights I’ve ever seen or used, but they are really well built and are quite a bit brighter than I expected. The adjustment knobs are awesome and make aiming the light a breeze.
The bracket is very well made with a really nice textured powder coat finish. Everything fit perfectly and was very easy to install. However, there’s a problem with the mounting location on the Raptor’s bumper that’s likely going to make me take them off.
Since the bracket uses the accessory mounting bolts on the bumper and the lights don’t have side to side adjustments, they’re permanently aimed way out in the ditches instead of straight down range where spotlights typically aim. Bummer.
If @RTR Vehicles happens to design a bracket that adds 2 more HP.70’s in the center (without drilling holes in the bumper), I’ll be the first person in line to get one! Until then, it looks like these will go on the shelf and get replaced by a couple of Baja LP6’s like I installed on our other Bronco. To be fair, I had to reverse and modify the Baja bracket to fit on the bumper without touching the grille, so it wasn’t an easy or simple install.
I’m not knocking RTR at all and this really IS a quality kit, I think it’s just the wrong application for me due to the limitations of the mounting points on the bumper.
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! D7596223-537B-4E85-9879-E6A5C770C635
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! 7C008B8A-F3A3-4E8C-992A-69D505410283
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! F058EF73-3E47-4815-99A0-4EADE7919536
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! 910C0B36-9735-41BA-B5EB-C937831175AB
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! 75658F5A-665A-475B-A90C-6FA9276433DC
FLSTFI Dave
East TN
2018 Grand Sport, Carbon 65, 2017 F-150
Those provide good light. Lots on the side and in front.
Johnny Rebel
LA
The light output is great, but because of the way they’re mounted on the bumper, they’re ditch lights, not long-range spots. I thought I was buying spots.-
Here’s factory high beam only.
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! 91CC67CE-011B-4220-8C46-1AB8842CCC31
Here are the HP.70’s in the RTR bracket with a line drawn to show where they’re aimed. Notice the void in the center of the road where spotlights would normally point. It’s MUCH more pronounced in person.
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! 320FA21D-08F9-4114-AF90-4B4A439D2D60
Johnny Rebel
LA
So after partially disassembling the lights in the daylight and looking at the possibilities, I think the solution for my needs is a fairly simple one. if I loosen the inside bolts on the top and front of the mount and remove the outside bolts, there’s enough material to machine a slot in the outside bolt hole to allow for horizontal adjustment.
This will require the use of a spacer between the bracket and the bumper and probably require a longer bolt, but it’s really a pretty simple mod.
Pics to follow, hopefully later today.
Johnny Rebel
LA
Update: was able to drill a single hole in each mount and now they’re aimed right down the centerline. These things are BRIGHT! Loving them so far.
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! 0BE83958-3B01-4FFB-A8DD-16E24BC406D2
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! 0AD9233E-835B-4278-B9C1-87823A0A6E7F
FLSTFI Dave
East TN
Nice. Looks like you found the perfect solution.
RTR Vehicles
RTR Vehicles
RTR
Concord, NC.
www.rtrvehicles.com
Bronco RTR
We spotted @vrtical during the Ponies in the Smokies All Ford Cruise In over the weekend! His Hot Pepper Red BRaptor was rockin' our RTR Front Bumper Light Mount Kit w/ PROJECT X Off-Road HP.70 lights.
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! IMG_7043
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! IMG_7033
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! IMG_7039
FLSTFI Dave
East TN
@RTR Vehicles , I really like that light set up with your bracket. I am thinking about going this route. I have a question though, would you be able to modify the brackets just a little so I could use them? The inter fasten on each side just above the recover point for shakes, I would nee the whole an oval like it is, but large enough to go over the fastener. I have after make recovery point that hold my winch mounting plate. I can not unscrew them.
For me to unscrew them, I would have to remove my winch, the mounting plate and then the bump. Bumper has to be removed as the recovery point is what holds the bumper on.
I have attached a picture of my winch set up and also the whole I need big enough and oval to go over fastener. Thank you.
See how the fastener is directly behind the recover point and mounting plate.
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! IMG_2677
Circled in red is where I am talking abut making it an oval to go over fastener. The inside one on both brackets.
Ford Bronco RTR Front Bumper Light Mount Kit for BRaptor! RTR
vrtical
Doug AI
GSMNP, TN
Fords
@FLSTFI Dave if I understand from your pics, you need that inner bracket front hole to be enlarged so it goes over the bronco bolt you cant get to and just utilize the remanding 3 bolts to hold the bracket? If that is the case, that is an easy mod I dont think it needs to be oval just enlarged for the bolt head which are not that big. You can use a step drill bit for this.
Status
