- Josh
- Apr 25, 2022
- 379
- 536
- 179
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
Rough Country's 3rd Brake Light Extension Bracket
Available here : https://ticklemybronco.com/products/ab-fb-rou-51051-prm
Please use AN5 discount code for additional savings
Rough Country's 3rd Brake Light Extension Bracket is the easiest solution to relocate your 3rd brake light above an aftermarket wheel and tire. This easy-to-install bracket keeps your 3rd brake light visible with up to 37-inch tires carried on the rear tire carrier.
The Bronco's factory 3rd brake light is designed to be visible above your vehicle’s stock 5th wheel on the rear tire carrier. Many drivers choose to upgrade to larger wheels and tires, which can obstruct the 3rd brake light from being visible. Some states require that your 3rd brake light be visible at all times. This quick and easy upgrade adds additional height to the 3rd brake light allowing it to peek over aftermarket 5th wheels and tires for better visibility and safety.
Includes Rough Country’s Lifetime Replacement Guarantee.
FEATURES
NOTES - IMPORTANT
No cutting or wiring required.
Does NOT fit Sasquatch models.
Fitment: 2021-2023 Ford Bronco 4WD
FEATURES
- Easy to install.
- Durable powder coated steel construction.
- Clears up to a 37in spare tire.
- Retains factory 3rd brake light.
- No wiring needed.
- Extends 3rd brake light over aftermarket spare tire for better visibility and safety.
NOTES - IMPORTANT
