Rock lights. Worth it getting installed from factory?
Cornbred
Georgia
17 F-250/Edge, 14 F150,202? Bronco Base/Raptor
Did you completely miss my point? The average person isn't wiring shit into their trucks. Those who are will get the switches. The rest will go "upfitter switches? What the heck are those?"
Make em standard and you're just gonna have a bunch of confused people wondering why that row of switches doesn't seem to do anything.
no I did not.. It’s pretty obvious you have no idea about them. Once you have them or had them you’ll wish they were available. And, how much sh!t comes on a vehicle that is useless or set/used once and forgotten about and your going off about something that is very useful, user friendly and saves a ton of time. Ask anyone who has a raptor or super duty and they’ll tell you the exact same thing I’m telling everyone here.
beachman101
;pkl
I wish they weren't even a factory option. The last thing we need is even more BROS running around with bright ass white "underglow" on the streets. Easy install for those who need them.
not even sure running them on the road/highway is legal
and i do need them because they seem to be an excellent exterior lighting solution for the things im going to be doing (fishing on the beach for example)
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
For the same price, you can get RGBW Rocklights
Ford Bronco Rock lights. Worth it getting installed from factory? 1607548186145
Why pay for just one color?
Rogues Gambit
Eatontown, NJ
how reliable is the bluetooth stuff
Depends where you get them from, but got Oracle DRL's on my truck and the only time it got stuck on red, pulled the fuse for them, put it back in and good as new.
Shop I'm going to uses Heise, say they're solid, getting them installed next friday, see how it goes
WCP-82
Ohio
2023 Badlands
I don't know if I need them or will use them but I'm going to have fill up those aux switches with something.
Bronco_joe
joe
Niagara Falls. NY
opt 7 lighting has 20% off there rock lights right now. 1-2 yr warranty depending what you get. good quality stuff from them at reasonable $$
Lagrange 6g
Tony
Austin , tx
2018 f250 2014 landcruiser 1978 cj5
Really? I thought they pre-ran connectors to different spots around the vehicle? Either way, I'll take that bus spot under the hood too.
They don’t. I have them on my 18 250 and they terminate in engine bay. You have to do wire run to acc
The Bronze
Kelly
1986 Suzuki Samurai, 1967 Ford Bronco, 1993 Turbo Notchback, 2006 Sierra K1500, 2013 Sierra K1500, 2014 Sienna Mini-Van
The 4 rock lights offered are t enough for me. I use my rock lights often; spotting over tougher sections, installing/removing chains and each time I am off a trail, I try to get under and take a look for any damage (especially after running chains). I have 8 on my EB and 6 on my Samurai. I tend to run the cheaper ones, but look at the reviews for the Amazon units. One manufacturer has very ooor results with blue tooth connectivity. I had to return a set that connected once and never again. Turns out a lot of reviews concerning that problem.
RBF 1401
Tricia
Tucson
98 Avalon, 95 Dakota
IMO, they don't need to be standard as long as they are such a cheep option. 90% or more of the people buying trucks (including the Bronco) are never going to add a single accessory...ever. Outside of gearhead forums, most people couldn't even hook up accessory lights themselves even with the pre-wired aux switches. So they will pay someone else to do it anyway.
WCP-82
Ohio
2023 Badlands
I disagree. I have aux switches activating nothing. I am going to need to flip at least a couple of switches and have something happen. If it didn't come standard with BL then I whole heartedly agree with you.
Hoofnmouth
mark
N ca
ford focus st
Good to know. I don't mind wiring stuff up at all but wanted to avoid drilling thru the firewall. If we can hook them up to a common box under the hood that is tied to our switch panel then I will do it myself as well.
just and old trick i learned from a master, anytime you need to go thru the firewall for wires get a piece of small dia. tubing can be anything i used an old carbon arrow.
Usually theres a seal somewhere good place to look is around steering column put an angled point on the tube and shove it thru ,feed wire thru tube,remove tube,and for good measure add some black rtv sealant .
Thats why the aux switches are a good deal its all done and they will most likely be terminated like the raptor under hood on pass side.
lowmpg
Ryan
Maryland
F350
I wouldn't buy them from Ford. If you get the BD model or up, it will have a rocker set of switches on the ceiling that is pre-wired to different locations around the vehicle. Should technically be very easy for you to add lights after the fact.
They aren't prewired to different "locations", they are just prewired switches. You'll still need to run cable from the footwell area.
To the OP, yeah it makes zero sense to buy through Ford for that markup. There are a bunch of LED light options you can mount yourself far cheaper and the wiring is simple.
lowmpg
Ryan
Maryland
F350
Hmm, I used all mine. I don't know anyone that hasn't used the switches in any Ford truck that had them.
AzScorpion
2019 Ford Ranger SuperCrew Lariat 4x4
The Ford lights are way overpriced. If you're not a DIYer or don't have anyone to help you it's not a bad way to go.
These are the ones I'm getting from Lux. They're a little more expensive (buy once cry once) than the cheap ones from Amazon but I know several who have them and they work great and really light up the underside. The biggest plus is they're magnetic so you don't have to drill any holes and you can also move them around for better placement/adjustability. They also come with longer leads (10' & 20") so you shouldn't have to buy additional wiring.
https://luxlightingsystems.com/prod...-light-kit-for-trucks-8-piece-ground-coverage
Ford Bronco Rock lights. Worth it getting installed from factory? Lux Rock Lights
