Reveal Bronco - Different Rear Suspension Components
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
Actually it does get old.
On the bright side they did get rid of the rear swaybar ;)
Does production have a rear swaybar? chassis pics from ford do not show one. I forgot to look at the event.
Julz670
Julian
Minnesota
www.youtube.com
Previously: '83 and '95 Bronco XLTs. RIP.
I'm guessing this model doesn't have the drive shaft because it just has a little electric motor connected to the front wheels. Doug DeMuro did a video using the orange display model and it just had an electric motor to move around while setting up displays.
Felix808
SRV CA
The Pope
There is no rear sway bar.
This is where a Disconnecting Sway Bar like the BL has, if mounted in the rear suspension, could help with Tow Capacity. Currently the SDC in the BL re-connects at speeds above 20MPH. A rear SDC could be setup to only be connected at speeds above a certain MPH.
FoMoCo... you already have the system, just add provisions to the rear suspension where this could be added and make the sway bar part of a Heavy Duty Tow Package.
RPF
FL, HI
11 Raptor 15 Q70S/5.6 19 F-450 21 Bronco FE
That looks like a rear end from the Everest for the Asia-Pacific market. The Thailand plant uses a different rear axle supplier and their axle uses a drop-out center section. Remember, T6 was developed by Ford Australia.
The Pope
Hint hint, Everglades trim though it won’t be disconnecting
Hint hint.... if it doesn't have the ability to be disconnected, it will limit the rear suspension articulation...... :rolleyes:
The Pope
The "current" design (2021MY) that we've seen doesn't have a Rear Sway Bar....
My "suggestion" was one that wouldn't hinder the Rock Crawling Folks and would "possibly" help the "tow rating is too low folks".
But whatever..... :rolleyes:
