Removable hard top Vs. Modular hard top
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
You aren't alone. I feel dumb
See, apparently grey is only offered in the MIC but black is going to be the regular hard top.
What does that mean LOL
Wait...what? Why? That definitely makes no sense.
BroncoKong Jr.
Andrew
I read this entire thread and still can’t figure out the difference between the two. :/ Somebody help me. Lol. What is the exact difference between the MIC and modular hard tops specifically for the four door version.
The modular top has removable rear quarter windows. They're made of different materials, and the modular is slightly heavier. And painted.
Lilj4425
Jacob
Greenville, SC
Thanks for the info. Any word on the weight of each? As long as the weight isn’t too much of a difference and I can get it in black, I will definitely go with modular as I want the removable rear quarter windows.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
4-door breakdown:
MIC: Stands for "Molded In Color" meaning the top is made molded out of a colored composite. 4 removable pieces. Two over the front seats (driver, passenger), one over both rear seats(the width of the vehicle), and the clamshell.
Modular: Built in pieces and painted. Heavier as a result, but rumor is that it will also be quieter. 6 removable pieces... the exact same 4 from the MIC, plus the two rear side windows on the clamshell.
No word on weight differences. There was an argument at some point what percentage difference it was, but even that devolved into a semantics fight (30% lighter vs 30% as heavy vs 30% heavier)
:EDIT:
Hello, it’s me from the future.
I wanted to check in and point out that @BroncoGuy clarified the construction later in this same thread. Here’s what he said:
The MIC and Modular both use the same manufacturing process and materials with the exception of the outer shell. On the MIC a thinner thermoplastic sheet is used, while on the Modular it's a thicker SMC sheet.
Lilj4425
Jacob
Greenville, SC
4-door breakdown:
MIC: Stands for "Molded In Color" meaning the top is made molded out of a colored composite. 4 removable pieces. Two over the front seats (diver, passenger), one over both rear seats(the width of the vehicle), and the clamshell.
Thank you. :) This info helps a ton.
Yolobaggins
Toyota Rav4
4-door breakdown:
Thank you for this. So the modular has more pieces BUT you can remove different parts of the clam shell, meaning it will be much easier to remove the hard top completely (1 person easily)?
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
removing the glass first will certainly reduce the weight... but, the modular with the glass removed may not be lighter than the MIC top together... and either way, a Ford rep yesterday said that no matter what, it should be a 2-person job.
(Speaking from Jeep experience, even if you were capable of lifting it by yourself, navigating it off the vehicle with the roll bar and around the gate/spare... you'd want a second person anyway.)
BroncoKong Jr.
Andrew
A Webasto (hard top manuf.) employee on here said the modular is about 50% heavier.
If you take the rear windows out, it'll be much easier (lighter) to remove.
indio22
Chicagoland, USA
o_O hmm, 50% would be a significant difference in weight. I'm surprised to hear that.
I could see needing some different design around the rear side windows, that might increase the weight. For example, some additional bracings and framing thickness around the windows, and on the windows themselves, along with latching mechanism.
But how much weight would that add? I'm not sure why the entire top would need changes.
BroncoKong Jr.
Andrew
Aside from the removable windows, everything else about the modular top seems to be different, down to materials and construction.
Yolobaggins
Toyota Rav4
Here is the $1000 question
Which one should people get?
Cause let’s be real, the soft top looks like garbage
indio22
Chicagoland, USA
I'm surprised at that. Especially if Ford makes the driver/passenger top panels different. Will be interesting to see the two tops up close eventually to compare.
BroncOBX
Rick
NoVaStan: Land of the Petulant
www.polaris-intel.com
2012 Ford F-150 FX4; Mavic 2 Pro
This is the same question I have. I want to know on the 2 door, if I can remove just the sides and back and leave the rear top on. How modular is modular?
+1 Exactly...how modular is modular and what are the structural differences? Still trying to get my mind right about after almost three months.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
2-door breakdown:
MIC: Two removable pieces per the front seats (Driver and passenger) and the rear clamshell.
Modular: Exact same as the MIC, with an additional "gunner hatch" porthole thing over the rear two seats. Initially it was said that it also included rear removable windows... but a ford rep since said that wasn't the case. I don't believe we have had it officially confirmed either way. (B&P Where are you?!!)
Construction differences between the two are the same with the 4-door. My understanding is that each piece of the MIC is essentially a single molded unit. The modular top pieces on the other hand are comprised of components that are "assembled" to one another, resulting in a heavier unit.
::EDIT::
Another update from the future.
2-door Modular was “confirmed” by Ford rep to have removable rear windows.
And as I noted earlier in this thread, here’s the construction differences:
Killed By Death
NC, 'Merica
BMW M2C
2-door breakdown:
Thanks for the summary! I was trying to read through all 9 pages to get the best 2 door answer.
I'm only interested in rolling bikini style (i.e. Rear windows removed). Doesn't look like that is happening for the 2 door. Gunner hatch only? No thanks, I'll save my money.
