Refinished wheels
88to21bronco
Tennessee
2017 Nissan Titan XD
I posted this thread a few months back on sprucing up some used wheels and, aside from some expected sarcasm and a dismissive suggestion or two, I found no guidance. So I decided to strike out on my own. I bought the wheels and tires for $700, after putting 33's on the stock BB wheels and not liking them. Since I had worn out my wife's good will with those two purchases--not to mention the Bronco itself--I decided to try to fix up these wheels as cheaply as possible. Here is what they looked like when I bought them:
Ford Bronco Refinished wheels 20220201_152700
A close inspection shows some rock rash--not a big deal--and the rusted bolts, which I discovered was somewhat of an issue with this style Fuel wheel.
I started by removing the bolts and cleaning the wheels, the fake beadlock ring in particular (since it would be the only thing painted).
Ford Bronco Refinished wheels 20220425_192442
I bough the products pictured below at Lowe's. I chose to buy these things rather than use kits I found online because I wanted to inspect the products in person. The goal was a good job that could get me by until my wife forgot how much money I've spent.
Ford Bronco Refinished wheels 20220425_192547
Though I've never used Bondo, I've done plenty of drywall and woodworking, so I'm familiar with the process of filling, sanding and painting. I had to go through some trial and error when it came to mixing the Bondo, though. Good times.
Ford Bronco Refinished wheels 20220427_143013
With the sanding, filling, resanding and prepping with Scotchbrite pads done, the hardest part was masking off the wheels. I've never had to mask of a 3D round object. It was a test of my limited patience, but I did a passable job.
I had a difficult time finding replacement bolts. They are m8 x 8mm, and finding black would really be difficult. My guy at the local hardware store suggested stainless, so I ordered 100 of those (I had to go back for 24 more...I forgot the spare. What an idiot). At ~$300, it was still cheaper than new wheels.
Ford Bronco Refinished wheels 20220428_122725
Ford Bronco Refinished wheels 20220428_122207
After a coat or two of primer and a good coat of paint, I think they turned out pretty well. What little overspray I got on the wheels came right off with mineral spirits. I still have a little to get off the tires. I'll get to that today. The color is not exactly matched to Cactus Gray, but it's close, and it's complementary, and I think it's better than if it were identical.
In the end, under $400 and I have a new-ish looking set of wheels. I suppose I could have gotten them powdercoated for that, but what's the fun in having somebody else do what you can do yourself?
Now... I'm sure that tire machine will scratch them all to bits when I get new tires mounted. And I"m sure I'll get some new rock rash on them the next time I leave the pavement (yes, I use it as it is intended on occasion). But for now I'm happy, the checkbook is happy, and the wife isn't mad at me. Not bad at all for 1.5 days' work.
Joe 22
2018 Ford F-150 Supercrew
Looks great! You have any pics with the stock Big Bend rims and aftermarket tires you replaced the stickers with?
88to21bronco
88to21bronco
Tennessee
Here ya go... Toyo AT2's. Had good luck with them in other vehicles in the past. I just didn't like the stance. Plus, I put a lift on it and wanted to go to 35's.
Ford Bronco Refinished wheels 20210713_154539
Joe 22
I’m looking to order a new set. I definitely wanna go more aggressive ,taller and wider but I’m not looking to lift it right now and I wanna keep the stock BB rims.
88to21bronco
88to21bronco
Tennessee
From what I've read on here, you could go taller--maybe 34.something--but wider would be the issue. Eithwr way, you'd more than likely either have to go with no crash bars or the modified ones you can buy.
Joe 22
Ford Bronco Refinished wheels 2812B794-A0BA-4B4F-B2BB-51FE449D6074
I like this look of tires but they look bigger than 285/75/17 so I’m hesitant about ordering.
broadicustomworks
Hanging Rock, North Carolina
Good deal.
The good thing is with using the Krylon is that you should always be able to grab a fresh can of touch up to refurb them at will.
Especially if you rash them up or whatever.
Purist paint guys may balk at you using can spray paint.
Me, I see it as a "If you are happy with it, and it is user-friendly, great!"
Bulk of your cost is in the new stainless bolts.
So subsequent refurbs will be paid for or just a few bucks.
EDIT: Invest in a roll or two of 3/4" and 2" 233+ 3M brand tape. You'll thank yourself later.
Curves and sticks a hundred times better than the blue "Painter's tape"
https://www.amazon.com/3M-26334-Aut...qid=1651172888&sprefix=3M+green,aps,78&sr=8-5
88to21bronco
88to21bronco
Tennessee
They're MT's, so that's why they are so aggressive. Not sure of the size. They don't appear to be 315/70/17's which would be 34.4.
If you're not familiar with offroad tires (you may be), the MT's will give you that aggressive look but will also give you the lovely "wha-wha" sound going down the road. Ask me how I know lol.
Joe 22
I don’t mind removing the crash bars it’s gonna be a mall crawler LOL
Joe 22
I know that sound all to well! Lol
88to21bronco
88to21bronco
Tennessee
Good deal.
https://www.amazon.com/3M-26334-Automotive-Performance-Masking/dp/B00494NVL8/ref=sr_1_5?crid=R648L19J3NWB&keywords=3m+green+masking+tape&qid=1651172888&sprefix=3M+green,aps,78&sr=8-5
You're right on the bulk of the cost being in the bolts. Fuel quoted me $2 per bolt for the replacements to the ones that already rusted. No thanks! I used a local company for about the same price, and like the stainless better.
I'm far from a paint professional. Again, I just wanted to make them look a little better and not break the bank.
Thanks for the tape suggestion! I'll check into that!
