Rearview Mirror Excessive Shaking
Stromad
Matthew
2023 Bronco Badlands 4dr 2.7L
In a 23' Badlands non-SAS with stock KO2's at 39PSI and my rearview mirror shakes to make the view look like a mirage! I noticed the mirror is has almost excessively tight resistance when adjusting the mirror, however when in position it has loose micro movement. I can feel the wiggle especially horizontal if I grasp and wiggle, isolating to the joint. Also if I hold the mirror steady at anything other than super smooth road the shaky-mirror image stops. This isn't even off-road btw.
My windows also shake like they're going to break in any position other than completely closed, but I'm following that topic on another thread and have gotten rid of some by adjusting the lower bolts. I say this because I'm curious if there's any adjustable tension for the rearview mirror...
Anyone else experience rearview mirage phenomenon?
Silver-Bolt
Eureka, MT
Drop your tire pressure. I had the same issue with the SAS tires. Dropped down to 34psi and it is a much smoother ride and no more mirror shake.
