Rear speaker flash
da_jokker
Jeep Wrangler JKUR
I tried the 3800 and the 0900 change in forscan but I wasnt crazy about either sound. I did both at one time, then each change individually and honestly my stock 382B setting had the most midrange, up front, when I change speakers.
It's a shame my 2017 F250 work truck has a better sound system than the Bronco.
What's a shame is my 2015 Wrangler has a killer oem system. Sub is like a 6x9 under the floor on the back and man it sounds good. Hits all sorts of frequency ranges, shakes the interior of my jeep... I'd swear they had a 10" in there.
I need to find someone with a b&o near me so we can compare.
imaginager
PDX / Oregon
2021 Bronco Black Diamond
I had mine flashed AFTER I replaced the cheap paper OEM rear pod speakers. Unrelated, but I also replaced the front dash speakers. In my experience the flash improved the sound from my upgraded rear speakers. I was concerned that I'd feel it wasn't money well spent - but knowing the end result, I don't regret the decision/expense.
Whitebronc35
SC
4runner
The flash improved my rear speakers too but in turn it took away the mid bass from the front. I replaced dash and rear speakers at the same time.
mbagne
Matt
Placentia, CA
Mach-E GT
It’s probably an hour of shop labor wherever you go. I tried to do it on mine but the flash wasn’t available for B&O. FDRS can be a pain in the ass so I think it would take 30-60 minutes start to finish but can’t comment on the outcome.
Is a flash required on the B&O system? I was hoping that the amp and wiring arrangement on the upgraded system would not have the same issue of underperforming, non-full range signal to the rear speakers. With the added sub in the B&O you would think that they would have upgraded the rear soundstage as well, for balance of sound.
bytheway
Brice
Louisville, KY
I didn’t add the soundbar, just tried the flash to open up the rear pods. They have the same tuning issue as the base system.
SCTWNB
Newport Beach
Cadillac Escalade
I have all upgraded speakers with the B&O system. To confirm it is worth to use Forscan to flash it to get better sound out of the rear pods? Thanks!
JL724
NY
Any news on the soundbar flash for the B&O system? Anyone able to get it successfully done to open up the rear speakers?
mck0721
MN
2022 Wildtrak
same question. did you ever get an answer of have the flash for the rear pods done on a B&O system?
