Rear end gears options?
Skeetlee
Gregory
Illinois
2021 f150
Will or is anyone offering optional gearing for the new bronco? I have a badlands standard and once I put 35 or 37 on I might want to change the rear end gearing. Anyone have any info on this?
Trueblue2296
Adam
Tennessee
2021 Badlands, 2022 F250 Tremor 6.7L
When you say standard do you mean MANUAL Trans or auto? If it’s a manual you already have 4.7 gear ratio witch should be plenty for those tires. If not you will have a 4.46 which is good too IMO. Hope this helps
okbob
North of the Red
71' u15, 66' u14, 66' u14
You'll also have to change the front end gearing. It's way cheaper to order the correct gears when built than to do it later after purchasing.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
It seems as though the manual BL is a tad over geared to start with. I'd put the tires on first and see how it feels.
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
4.7 “optional equipment “ that’s standard on Badlands builds.
wrbix
VA and FL
….but the OP has a BL.
Blksn955.o
Greg
Wentzville, MO
I would agree with this having a manual badlands on 33's. Obviously the Squatch comes with 35's and the same ring and pinion gearing. A 37 is the next taller tire I would have little doubts the 4.7 and manual would still be decent. Worst case it would probably make your rig with 37's and 4.7...feel more like 4.46 rigs.
grayshadow
Charles
Humble, Texas
No sir. Here is the gear ratio by model and transmission choice.
Ford Bronco Rear end gears options? 89106322-37A6-4DCE-92B0-3A395AE074C7
Drex
Jake
4.7 is standard on manual BL.
4.70 is standard on ALL Badlands (as they all come with the manual transmission standard). If you pay to get the optional non-sasquatch automatic transmission, it changes it to a 4.46 ratio. Semantics of course, but people should not forget Ford decided the BL should come from the factory with a manual transmission as the default configuration.
Tricky Dick
Dick
PNW
You’re....not wrong. So technically 4.46 is the optional gearing on BL.
Trueblue2296
Adam
Tennessee
It’s standard on a manual transmission Badlands. Option on an auto unless you get SAS then its standard.
sgraing1
451xx
2022 Bronco Black Diamond.A Bunch More Junk.
If the gearing is your priority buy the model or features (Sasquatch,tire size) that suits your wants and or needs. Practically speaking, gear changes on a new vehicle aren't a wise way to spend your money.
