Don't forget our CA smog check,All this talk of inspections on this forum makes me feel a tiny bit better about CA.
Starts about 4 years in then every couple of years after that
Still far less intrusive than some states
So I guess you don't care about whatever dashboard warnings or buzzers go off every time you put it reverse?![]()
Or Just delete it.
? i dont have that issue on the JeepSo I guess you don't care about whatever dashboard warnings or buzzers go off every time you put it reverse?
Anything's possible, if disconnected it could be a non factor or it could be an annoying chime every 8 seconds? i dont have that issue on the Jeep
i still have the rear camera. it just deletes the spare tireAnything's possible, if disconnected it could be a non factor or it could be an annoying chime every 8 seconds
Depends how ford has their system programmed
With how complicated and connected cars are today I would not assume you can just take parts off without possible side effects
Pretty sure the smog starts at like 8 years now. Still haven’t had to do one for for 2013 Escape.Don't forget our CA smog check,
So hard to keep track, I've got an 2011 and I've smogged it twice so farPretty sure the smog starts at like 8 years now. Still haven’t had to do one for for 2013 Escape.
