RCI Cross Member Skids installed :)
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Any thoughts on Steel vs Aluminum? I want to order today but keep going back and forth. I am thinking aluminum for weight saving and they say 2/3 the protection of steel.
100% go with Steel. You won't regret it.
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
Installed the skid system today by myself and it was easier than I imagined. Still awaiting my gas tank skid from RCI and realizing that’s gonna be a pain to install.
also just ordered some bolt head protectors for the front 2 bolts on the RCI bash plate. (Ordered from north ridge 4x4). Should protect those front bolt heads way better.
What made you go with RCI for the LCA skids? I've been looking at JCR v DV8. LCA and rear shock are next on my list.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Bird Dog Off Road
Jody
Dallas, TX
www.youtube.com
My cross member skids have shipped and are currently on the way. I have Full RCI aluminum skids, Aluminum Fuel skid, Steel A-arm skid, and Steel rear Diff skid (pending install). Have their Sliders ordered, but they haven't shipped. RCI has been around for a while and I used them for a lot of things with the old 4Runner.
Ford Bronco RCI Cross Member Skids installed :) IMG_1828
Ford Bronco RCI Cross Member Skids installed :) IMG_1824
Bird Dog Off Road
Jody
Dallas, TX
www.youtube.com
Just my opinion, but I prefer steel with the A-arms and rear diff skids. If I was going to stick with steel (my badlands came with full steel factory skids), I would have only replaced the transmission skid to address the gap between it and the T-case skid. IMO, the stock skids are pretty tough and will work fine for most people. I went with Aluminum for most of mine due to weight savings and I live in the rust belt of the Midwest.
I had RCI aluminum skids on my 4Runner and they did great in Moab and Ouray a couple years ago.
DangerMTBBronco
Dale
Lake Elsinore, CA
youtube.com
2022 Bronco Badlands Sasquatch
Thanks! Yeah I have a Badlands as well but it lacks some protection as you said. I'm keeping the stock fuel tank skid of course. I ended up buying the RCI aluminum skid kit and then the steel cross member skids since they don't offer those in aluminum anyway. I'm also running the Next Venture motor sports rear shock skids already. Still undecided about LCA skids I honestly think it's overkill to protect the two shock bolts. I am considering other solutions for that like swapping the bolts but we will see. I may end up with LCA skids in the future.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Interested to hear your thoughts? I’m torn as well.
I have FULL RCI steel under my Bronco. Yes, they are significantly heavier but it also gives me great peace of mind. I recently ran into a "big" rock in the middle of a trail at about 40mph and my engine skid slammed into it and took the brunt of it. My Bronco was lifted off ground , landed on center and bounced off the rear Diff Skid (DV8) which is also made of steel. It punched a hole in my front engine skid and by the looks of it, had it been aluminum I definitely would have sustained frame damage. Maybe not major, but still more than I would have been comfortable dealing with. If you are primarily doing slower rock crawling and easy trail riding I definitely feel the aluminum ones are fine (and lighter). But I even went the steel cross member skids juuuust for that extra level of protection. Yes, they are also cheaper and I was toying with the idea of paying the "delta" in price to go with aluminum, but am overall happy with my decision to date :) The reality is that I rarely do crazy rock climbing very often. But on trail I enjoy driving more aggressively and faster, but not carelessly, than most do. Knowing I have steel all around gives me that extra level of confidence. Just my 2 cents from experiencing a "hard" impact and coming out of it unscathed ( I just bought a new front skid section from RCI and replaced it).
VentureBronco
CA
2022 Base Sasquatch 2-Door
i really like the bolt head protection, and wide plate with angles that RCI used. I also was Ordering their full under skids, so just went with a “full kit” (less multiple shipping costs) . The LCA skids are really solid and feel like they leave less “holes to get caught” and more surface area to spread any impact and slide. Even thought they are super easy to install, they feel very solid mounted , and not overly complex.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Agreed. the ONLY bolts that actually "protrude" are the TWo front engine skid plate bolts, which are exposed. I found a "skid washer" solution that takes care of that :)
From RCI (without solution)
Ford Bronco RCI Cross Member Skids installed :) BOLT1
with solution and washer installed
Ford Bronco RCI Cross Member Skids installed :) BOLT2
VentureBronco
CA
Yup. I got the same thing. But then sprayed some black paint on the head too.
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
Any experience sliding on these RCI cross member skids? I beat one of my cross members and am considering protection here.
Ford Bronco RCI Cross Member Skids installed :) 20230507_102321
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
No sliding but I have the WHOLE RCI undercarriage protection system. All Steel. I have experience hitting my front bash plate at 35mph into a massive rock that punched a hole in it - but completely protected my engine. If the rest of RCI stuff is built this way, I'm all for it :)
RangerDanger
Sean
El Sobrante, CA
2021 Ranger Tremor
Does anyone know if the T-Case skid is the same for the 4dr and 2dr? I ordered the 4dr but it looks like it's for the 2dr based on the directions (plus has an extra metal attachment that goes to the fuel tank skid). 4dr directions show an open slot at the two driver side frame connections, 2dr shows closed slots...
