Question about how to add reverse lights
smonroe11
smonroe11
Stephen
Dallas
Chevrolet Tahoe
whmoorejr
Bill
Friendswood
2023 Black Diamond
Did you get a reply on what type of diode to use?
I used a pre-packaged diode thing I found on Amazon. I like that it uses spade connectors (at the moment), so if I decide to remove one of the inputs (switch or reverse signal), I can just pull the connector off the diode thing. When I routed my wires, I bundled it up just behind that rectangular panel on the right rear.... So I would only have to remove that one rectangle to re-do any connectors if needed. Towed Vehicle Diode
smonroe11
smonroe11
Stephen
Dallas
Chevrolet Tahoe
Thanks. I’ll check it out!
Migo
Roy
Houston, TX
www.instagram.com
We actually sell complete kits with lights/harnesses
We also make 2-3 pigtails depending on the light needs
First, this is our reverse in-line connector. It plugs in-line with your tail lights and gives you a Weatherpack 2-pin connector to plug into whatever you want:
https://www.4x4truckleds.com/crystalux-wp-2-pin-in-line-bronco-tail-light-harness-2021-ford-bronco/
Then we also have our upfitter/reverse harness. This basically is a wire ran from the front upfitters to the rear of the truck, that plugs into TWO lights. It also has a connection to connect our IN-LINE connector (above) to. We make 2 varients of it
DT-2 Pin, which has a 2-Pin DT connector on it for lights such as Rigid, KC, etc...:
https://www.4x4truckleds.com/crystalux-dt-2-pin-reverse-harness-w-upfitter-control/
And then our WP-2 Pin version, which has connections for Baja Designs
https://www.4x4truckleds.com/crystalux-wp-2-pin-reverse-harness-w-upfitter-control/
On our reverse harnesses again they connect to the upfitter, run to the back of the truck and plug into 1 pair of lights. And then there is another connector (2-pin WP) that we left which connects to our in-line connector.
The benefit to our reverse harnesses is that IF you turn on your lights from an upfitter it WILL NOT back-feed your factory circuit.
I have this set up now and it works perfectly. But I would like to add a 3rd light. Can I just splice into this harness? Thanks.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I don't know if the truck will support 3 lights on the reverse circuit. So you COULD but i can't sign off on doing that
Migo
Roy
Houston, TX
www.instagram.com
What would you recommend? Also, can I use the same harness to power from the aux switch, but just unplug the reverse circuit?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Our harness is designed to be plug and play and works with our upfitter/reverse harness (which allows you to turn the lights on from an upfitter switch as well as automatically in reverse).
WP 2-Pin: https://www.4x4truckleds.com/crystalux-wp-2-pin-reverse-harness-w-upfitter-control/
DT 2-Pin: https://www.4x4truckleds.com/crystalux-dt-2-pin-reverse-harness-w-upfitter-control/
If using our reverse harness with SSC1 or SSC2 you have to remove the DT 4-pin connector on the SSC1/SSC2 and put a DT 2-pin connector on. Our reverse harness does NOT support back-lighting.
