ProComp 1069 Inner ProComp Circle Diameter
Bottomose
Tom Black
Missouri
2022 Ford Bronco
Hello everyone I am new to the Bronco6G. I'm glad to be a part of it. My wife and I have a 2022 Ford Bronco Big Bend 2dr. We are wanting to purchase Pro Comp 1069 17x9 wheels. Does anyone know the diameter of the inner circle that contains the Pro Comp logo? We are eventually wanting to purchase Ford Bronco overlays..... Any help would be greatly appreciated.
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter 1069-7983-04
ChrisB351
Shreveport, LA
2 1/8" or so
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter 20230710_165901
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter 20230710_165854
LarryBirdsFace
Maine
I have these wheels, interested to see what you find for overlays
Bottomose
Tom Black
Missouri
2022 Ford Bronco
Well my wife and I have been wanting to purchase new wheels for our 2022 Big Bend for a while. Before that happened, we replaced our fender flares with Sasquatch flares. We pulled the trigger last Friday and purchased a set of Pro Comp 1069, 17 x 9, with -6 mm offset. They were mounted on the original 255/75/17 Bridgestone Dueler A/Ts. I did do my research and the 9" wheel with is right at the limit on these tires. Even with Sasquatch flares, we have around 7/16" of sidewall poke (originally figured 3/16", but the backspacing is 4.75" not 4.5"); we could live with it as the tread is still roughly 1-1/2" inside. Also, we installed IAG Sasquatch specific mud guards as well; they were installed as shown in the last picture. I must say it looks much better and the 5" overall track width greatly improved the stability, handling, and ride! If you like the old school classic look, I'd highly recommend it! We looove it!
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter 5FORG6
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter 3forg6
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter 7FORG6
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter 2forg6
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter IMG_20230714_162715593_HDR~2
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter IMG_20230714_162918629
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter IMG_20230715_130303534_HDR
JL8jeff
Ewing, NJ
If you go with wider/taller tires in the future, you will most likely need to trim the mud flaps. I had to take a bit off the inside edge with the 35x12.5x17 tires but mine is a base Sas so it already has some lift. I ended up taking even more off the flap than what shows in the 2nd pic.
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter bronco_comp7
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter flap4
ChrisB351
Shreveport, LA
Looks great but I may be a little partial
Ford Bronco ProComp 1069 Inner ProComp Circle Diameter Bronco1
Bottomose
Tom Black
Missouri
2022 Ford Bronco
Thank you so much for the info. I saw a guy had 295 70 17s on his at full lock turn he was barely rubbing his crash bars! That is what is so cool about this website you got people helping each other it's really neat! Thanks again!
