Problems driving in sand
GToddC5
Todd
South Jersey
www.bronco6g.com
Just to add to my notes since reading others - I only use 93 from top tier stations. When it happens it feels like I could step on the throttle for days, but since in limp mode it only accelerates stupid slow, so maybe that makes you feel as if the brakes are on? I can eventually get to 45-55 to finish my trip, but I found it less aggravating to pull over and reset if feasible.
JaredWilm28401
JaredWilm28401
Jared
Wilmington NC
2023 Bronco
UPDATE:
After getting underneath the bronco and checking all my connections and tightening down the fuse panel I took it on the beach.
No codes, no boat anchor and she ran like a raped spider monkey!
I really wish I know which one of those things was the culprit but I didn’t have the patience to test it.
Y’all were super great in helping me figure this out!
I’ll be out stomping around in the woods on some trails tomorrow so I’ll post another positive update if all goes well!
Thanks everyone!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
What connections? What exactly did you do to the fuse panel?
JaredWilm28401
JaredWilm28401
Jared
Wilmington NC
2023 Bronco
I’ll be dead honest, I don’t know what they’re called as far as the connections go. They were attached to the wheel assembly (just the connecting fittings I could get to) On the fuse box, there are three 7mm bolts that that run down the middle that seemed loose.
Grant3168
Grant
Denver, Colorado
2013 G37, 2006 G35
UPDATE:
Thanks everyone!
Thats great! Hopefully that is the end all fix to this... Enjoy your steed!
Broncoco
Half Moon bay
2022 Bronco
Mine did the same in the sand. Was horrible. Like the brakes were on. Barely got out. Do you all run sand with advancetrac off? It's the only thing I didn't try. Has anybody run the dunes with advancetrac on? Just curious. Otherwise I have some kind of sensor issue.
