I am in a similar place. Got the bronco in Feb, paint is still fresh, and deciding...do I just get mud flaps or do I fork over $5+k for PPF that might work? Based on my reviews, I did allot of research and calling all over for quotes and questions, PPF isn't perfect. It helps but is not an iron curtain. There is no iron curtain. There are two main areas that get hit the most. The very front of the hood and right behind the front tires (rocker panels and doors). If you can cover those two areas then you will have protection from at least 70% of the possible rock chips/debris. I already put in RCI rock sliders ($1200) which come out several inches and protect against rocks being kicked up. They also protect against door dings. Check. I installed a aero hood protector ($65) that covers the first 5 inches of the hood. Check. My next installation will be RockBloks mud flaps ($419). So that comes out out $1684. So I compare that to $5000 for PPF. Keep in mind PPF peel and when it does take a hit, it makes a mark that it noticeable. If you have the money to throw....then why not. I like it, but think my current set up will do just as good for allot cheaper. I also thought about how I never had PPF on any other vehicle and it wasn't an issue. Had a wrangler, prior to the Bronco, no PPF and I would off road it often. I had no dings at all. The one thing that did get me was pin striping. A proper wash and wax would help remove them but if you looked in the right light/angel, you could see them. I do think PPF could definitely help with pin striping. If you plan on off roading between brush then PPF would help considerably.
