PPF or Ford Trim Kit for rocker panels.
Benjamin
Good afternoon,
Just took my new bronco out on the trails and picked up some small scratches. Does anyone have a preference to PPF placement or the Ford deco, black panel trim kit??? Thoughts on longevity and durability?? Thanks in advance!!!
Ford Bronco PPF or Ford Trim Kit for rocker panels. IMG_4970
Gene Dios
Atlanta
Light to medium scratches will buff out. If rocks are a concern try some sliders that stick out more. If it's tree branches it will buff out if it even does much of anything in the first place.
On my precious bronco a did a strip of black vinyl from the bottom up to the first pinch /bend body line. Aesthetic choice, not really helpful for scratches.
If you're really concerned just do front and side xpel or similar. Job isn't cheap though
03SVTL
PPF for the rocker panels, not for pin stripes but rock chips kicked up by your tires.
Bovas
Robb
Newark, New Jersey
2023 ford bronco badlands
Those scratches seem light and will clean off after a while , but a PPF for the rocker panels might work.
23OBX2.7
AB Canada
2023 Bronco
Today I say the same trim kit for Maverick and noted how it effectively blocked body side splatter above the trim.
I personally did mud flaps and the Ford black rocker panel trim no chips or pitting after 10000 miles.
I am intrigued by the trim kit though but I can ppf each lower door for only 140 a side.
