Pocket Lights - Mod Bumper
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Which setup is this, exactly? There are many options on the following page (drop down boxes). If you have time, can you please let me know which ones you are running?
https://www.4x4truckleds.com/baja-d...ad-bezel-flush-brackets-for-2021-ford-bronco/
That's the Baja Designs Kit:
Squadron SAE, Amber
S2 Sport Driving/Combo
S2 Sport Spot
However we actually let you customize/select what lights you want depending on the output/patterns you desire. We have some recommended setups on the page.
But that setup comes in at $979 (use coupon code FOGS and save $48.95 more though)
Ford Bronco Pocket Lights - Mod Bumper 1667880284605
JackTripper
JackTripper
The Beach
Enough
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Sweet. Thank you.
No problem. We've got plenty in stock. Get your order in before 12pm EST and it'll ship the same day (so basically order it right now, it'll ship out tomorrow morning to ya)
Moto26
Tucson AZ
I ordered some ditch lights from @4x4TruckLEDs.com (based in NY) on Wednesday afternoon, and they were in my mailbox in Tucson on Saturday - and the shipping was free. Amazing! Mounted them Sunday...
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Thanks for the business. We stock pretty much everything we sell and get orders shipped out as soon as they come in the same day (if UPS hasn't come by anyway)
JackTripper
JackTripper
The Beach
Enough
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Getting ready to pull the trigger.
How do you compare the Baja Designs vs. the Rigid setup shown below?
https://www.rigidindustries.com/2021-bronco-mod-bumper-triple-sr-m-fog-light-kit-46731.html
We don't... the Baja are far superior fo the Rigid setup, and less $$
https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/fog-lights/
Baja Designs are assembled in the USA with a lifetime warranty and we let you choose what lights you want to go with. The patterns and optics are far superior.
JackTripper
JackTripper
The Beach
Enough
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes they are. The S2 Sport are 1130 lumen each and the S2 Pro are 2450 each. So you get more then 2x the output. I always recommend Pros on our triple fog kits because the 2" pods are smaller lights you won't get as much light as the 3" pods
Instead of that Spot S2 i'd say go with a Wide Cornering S2.
You have your street legal fog and then you can also have the S2 Pro WC as a secondary fog. While not "street legal" when aimed down low it should not cause any glare to other drivers, and it's a nice wide pattern even if you don't use it on public roads and just off-road.
The driving/combo contains a spot and driving so maybe go with a Spot on that instead.
Basically S2 Pro Spot & S2 Pro Wide Cornering
JackTripper
JackTripper
The Beach
Enough
Thank you for the feedback. I’m going to take your advice and order the following is this correct?
1st Pair:Squadron SAE, Wide Cornering Amber (+$60)
2nd Pair:S2 Pro, Spot (+$80)
3rd Pair:S2 Pro, Wide Cornering (+$80)
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yeah that's a good setup for street legal amber (yellow output) fogs. And then you've got some off-road lights (as I said, you can pretty much get away with the S2 Pro wide cornering on the roads if you make sure you aim the pattern below your headlights).
FellowM3
Northern NJ
Current: 22' Braptor, 2020 BMW M340
I bought the Baja Designs pods. One is amber; two are white - hooked up to two different AUX switches. I actually use the amber far more than I expected to - great for fog, smoke, rain, and snow.
I think I may go with the same. Good point about fog rain and snow
4x4TruckLEDs.com
Adam
Lindenhurst, NY
It's a good setup. We list some recommended setups on our Fog Kits:
Make sure you get the kit with the KR Off-Road brackets so you can select your lights, get our all-in-one harness AND save some $$$
If you want to run larger lights, our open-style bracket would be the way to go:
https://www.4x4truckleds.com/baja-d...-w-kr-off-road-brackets-for-2021-ford-bronco/
And of course we also have Diode Dymamics as well here:
