Plant hold status. Anyone else?
SGXIX
Anyone else currently on "plant hold" status?
ChrisB351
Shreveport, LA
Mine spent 4mo in that status before delivery. Noone could ever give me a straight answer.
SGXIX
Damn, that's not good! Can you share what was the reason of the hold? If you ever found out lol
SGXIX
Im ok with holds being called just not on the last play..damit..
I know, it's awful. From one hand can be a good thing if they found fault before releasing for shipment, but on other hand no idea how long plant hold will last depending in what kind of issue they could have discovered
Derbystud
2011 F250 6.7
My plant hold was for a headlight issue I was told. Sat for 2 months until the summer factory shutdown then got fixed. Then sat for another month before getting shipped.
SGXIX
Would you say I should keep following up with dealer or with Ford? Or it doesn't matter because end of the day they will fix it whenever they like?
Derbystud
2011 F250 6.7
I don't think your dealership has any info and I'm not not sure ford will tell you. Someone in my build week had a friend at the factory, she asked him and he is the one who told her what was wrong. Then it was just a waiting game until ford decided to fix it.
Bronco1020
Lebford1
2022 f150
Mine has been sitting as “produced” for 10 days now. Meanwhile my dealer has received several that were built after mine. Tomorrow is the last day of the delivery estimate, and no answer yet.
HBTFD
Newnan GA
F350
A plant hold can be just about anything. An inspection that wasn’t bought off, open repair not bought off, calibration record did not load, suspect for missing/defective part/not torqued, etc. Unless you know someone that can access MAP’s quality system you’ll never know why.
SGXIX
That's what I'm thinking. Unfortunately don't know anyone at the plant. Bad luck I guess and waiting is the only thing to do at this point. Hopefully nothing that affects the build during life of ownership
HBTFD
Newnan GA
F350
Over 99% of vehicles on hold will not have a latent issue due to the hold. Most vehicles on hold are released without any physical work being done. Don’t sweat it, I hold you get your bronco soon.
