Pinstripe ideas?
Lowcountry Bronco
William
South Carolina Lowcountry
Heritage Spear Kit in Gloss White Aluminum (Silver) from Underground Graphics.
Do you have a little closer up pic of the stripe? I'll probably be removing the factory white Heritage stripes to get rid of the Bronco sticker and want to replace with the 2 color stripes from UG. Was thinking the aluminum for the outer and either a gray, black or red for the center to somewhat mimic the EB spears ... will also be adding the AR base base badge!
Thanks!
Grizzle
Toby
Lenexa, KS
2018 Honda CR-V
Thanks!
Here you go.
Ford Bronco Pinstripe ideas? IMG_1090
Ford Bronco Pinstripe ideas? IMG_1089
Ford Bronco Pinstripe ideas? IMG_1092
CJD100
CJD100
Boston, MA
21' 2dr Wildrak
Yes! ^^^ this! This is exactly what I envisioned as I thought about this topic. Simple and clean. Other banners are just too much in my opinion.
This looks so clean and nice
Grizzle
Toby
Lenexa, KS
2018 Honda CR-V
@Grizzle I have iconic silver and was going to do white, this is listed as white gloss silver, does it read at all like white?
Even though it's listed as white gloss sliver, It reads more silver to me. I have the Satin Silver Bronco Script, and while they aren't an exact match in color and finish to each other, they look pretty much the same from a few feet back. The white gloss silver might look a bit like a ghost stripe on top of iconic silver. It's hard to say as I haven't seen an iconic silver Bronco up close recently. Reach out to @Underground Graphics, and I bet they can probably send you a color sample.
Greg
Houston
www.undergroundgraphics.com
22 Bronco, 20 Jeep Gladiator
The Gloss White Aluminum is basically 3M's silver. Beautiful metallic and in direct sunlight it can look white. 3M white is juststandard bright white. And yes, we are happy to mail out swatches if you'd like! Just send us an email request with your info.
Greg ;)
