Phone mount for the manual trans
DrillRX
Bakersfield, Ca
2024 Ford Bronco BB SAS 2 Door 6 speed
I’ve found a decent solution for a phone mount for the manual transmission Bronco that is several products.
The First is the Tackform magnetic charging mount with telescoping arm and passenger grab handle mount. It’s not at all wiggly, nor any vibration when off-road, and the magnet is SUPER strong.
The second is the right angle, 1 foot long cable from a company called MEOU (Amazon), with either USB C to C or C to A, and seems like it should be part of the kit it fits so perfectly.
Third is a USB A/C converter for the 12 volt socket inside the center console for triple power options in the console.
The mount keeps your phone out of the way for the shifter, controls, and in no way gets in your passengers leg space like I had feared it would.
All these options pair well with my quad lock magnetic case i use on my motorcycles, but absolutely can be used on a mag safe case or any “naked” iPhone or magnetic housing android phone.
Ford Bronco Phone mount for the manual trans IMG_1188
Ford Bronco Phone mount for the manual trans IMG_1189
Ford Bronco Phone mount for the manual trans IMG_1190
Ford Bronco Phone mount for the manual trans IMG_1192
Ford Bronco Phone mount for the manual trans IMG_1191
Ford Bronco Phone mount for the manual trans IMG_1193
Fatfireman
JR
It doesn't look like they make that particular magsafe portion of your set up anymore. But it was good to hear that it does not bother the passenger compartment.
DrillRX
DrillRX
Bakersfield, Ca
Fatfireman
JR
