Passenger window not cracking when door opens
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Just seeing if anyone else has been having a small issue with the windows not cracking.
I noticed a lot of road noise coming from behind me. I rolled the window down and I hear a thud. Last time I opened the door the window didn't Crack or I opened too fast for it to register that I was opening. It's since "fixed" itself.
Recently my passenger door auto roll up won't work. Opened the door and noticed it's not sliding down. I disconnected the cable from the door. Didn't fix it. So I don't know what else to troubleshoot. Anyone have ideas?
I noticed after I plugged the door back in and shut it the horn double beeped. I don't know why.
carrellslake
Oregon
2022 Ford Bronco
The horn will double honk if the engine is running and the key is not in the vehicle when the last open door gets closed. Was that the case for you?
I have a similar problem where the passenger door window takes a little too long to roll down. The basic reset procedure didn’t work for me.
Ig_bronco
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
I disabled that via forscan. And the car wasn't running but power was on so I could test windows
Murfman
Colorado Springs
2021 WildTrak, Cyber Orange soft top
reset the window; open the window, holding your finger on the button and keep holding for 5 seconds after it is fully open. Then close it, holding the switch till it closes and then for 5 seconds. The window should be reset now.
Ig_bronco
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
👍👍👍👍 all good now! Thanks a million, I didn't know there was a reset window mode😂
MacDonald_Photo
Jamie
Eaton Rapids, Michigan
2021 Badlands
Thanks for the fix...All of a sudden today my window decided to stop dropping at open, and wouldn't go back up at close.
Fixed.
jacobim
2022 Bronco Badlands
Mine has done this two or three times the last few months. Resetting it fixes it for awhile... Wish I could get the update they started putting on the 2023's where all the windows crack when you unlock the vehicle. The window shake when opening the door is bad.
